C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Installing 100mm MAF
Old Apr 25, 2012 | 12:48 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Default Installing 100mm MAF
So I finally have my 100mm MAF setup coming in to accomodate my blower....finally.
Will I be able to install this in my garage and limp it to my tuner (about 8-10 miles away) or will it be totally fracked up until it gets dialed in a bit?
-Shawn
Old Apr 25, 2012 | 04:30 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
going from a stock ls2 maf to a 100mm maf? will not run with it plugged in.
you could install it, but NOT plug it in and the pcm will run on the VE table, and you can limp to the tuner, if you hit boost, your car will shut off/REP mode
-Carl
Old Apr 25, 2012 | 04:38 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Unplug your current one and see if it's drivable on SD/VE.
Old Apr 26, 2012 | 02:02 AM
ashanson's Avatar
ashanson
I wouldn't install the 100mm until you get to the tuner. I had the same situation two weeks ago. I drove to the tuner with the stock MAF and installed the new one at the shop. I was feeling risky enough to put in E85 with larger injectors ahead of time, but not the larger MAF, that is a huge change in airflow calculation.
It only takes a bit to install, why risk it?
Old Apr 26, 2012 | 07:53 AM
FloydSummerOf68
Good call
I'll do that.
To Installing 100mm MAF
