C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
external waste gate dump
Old Apr 25, 2012 | 01:15 PM
Abirli's Avatar
Abirli
Default external waste gate dump
does anyone have a video or audio clip of just how loud a twin turbo waste gate dumping into the air is?
i found numerous ones of the wastegate going back into the system, but none for going into the air
Thank you
Old Apr 25, 2012 | 03:08 PM
8seclxtal's Avatar
8seclxtal
It sounds like **** !! Don't do it !
Old Apr 25, 2012 | 03:51 PM
Ls240sx's Avatar
Ls240sx
Only sissies dump back into the exhaust
Old Apr 25, 2012 | 04:06 PM
Abirli's Avatar
Abirli
How does it sound tho? i actually like the loud and obnoxious sound it may make.
my brother told me that as cool as it is, i'll get sick of it for a dailyish driver
any audio of it?
Old Apr 25, 2012 | 04:09 PM
Ls240sx's Avatar
Ls240sx
no audio. I have built/driven plenty of open wg cars in my day. I personally dont mind how loud it is when they are fully open. In a "daily driver" how often are you really in boost enough that it would open the gates? My guess is hardly ever.
Old Apr 25, 2012 | 04:20 PM
Abirli's Avatar
Abirli
very true sir. i think ill prefer it open as opposed to back in the system.
Thank you for your comments
Old Apr 25, 2012 | 04:23 PM
user_name's Avatar
user_name
Aren't you just going to hear it under boost when they are bleeding it off? Why would that be bad for a daily?
Old Apr 25, 2012 | 10:05 PM
Abirli's Avatar
Abirli
I think my brother was just saying that he thinks ill get tired of the sound, and it becomes old after a while.
But i personally think that ill enjoy all the noiseee
Old Apr 25, 2012 | 10:15 PM
user_name's Avatar
user_name
Well i have a ttix kit that wont make less than 17psi without creeping. Looking at the design i think i could knock that down a bit so i am considering doing this myself.
Old Apr 26, 2012 | 01:53 AM
ashanson's Avatar
ashanson
I have run both external dump and re-routed back into exhaust. I will never run open dump again, it's just too annoying. True, it only dumps when you have reached wastegate pressure, but it sounds like a jet is taking off and gets old after a bit. To each their own though, if you like the crazy loud sound, then go for it.
To user_name: if you run an open down pipe, the boost will creep even more with less back pressure.
Old Apr 26, 2012 | 09:25 AM
Abirli's Avatar
Abirli
does the ssc ultimate areo external dump? i remember watching a video and think damn thats bad ***
Old Apr 26, 2012 | 10:25 AM
user_name's Avatar
user_name
I am running mufflers. That alone took 4psi of boost creep away, but I still make 17psi on 13psi springs or anything smaller.
Old Apr 26, 2012 | 03:54 PM
timmyZ06's Avatar
timmyZ06
not sure but, usually when running ext dumping gate it should prevent boost creep. because it help wg to flow more less back pressure which will flow better and quicker. but less back pressure in EXHAUST system will more likely created boost creep. my single turbo supra is external dump sound like a jet, its not annoying since i hardly fully boost on the street. i had boost creep problem with the sti, cause wg wont flow enough, put a external one problem solved
Old Apr 26, 2012 | 04:17 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
I'll post my experience. This was on a 70mm single turbo with a 38mm tial wastegate. At WOT, it sounded like I ran over a Harley motorcycle and it got stuck under the car with the exhaust pipes point at the firewall.
You couldn't hear anything when not in boost, but as soon as the wastgate opened, this was the only sound I could hear. It attracted the wrong kind of attention from law enforcement due to the noise.
I modified a lawnmower muffler and put it on the outlet of the wastegate to knockdown some of the noise. It made the sound bearable.
Old Apr 26, 2012 | 05:23 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
We want videos
Old Apr 26, 2012 | 05:24 PM
breecher_7's Avatar
breecher_7
Originally Posted by SinisterC6
We want videos
You get your stuff yet?
Old Apr 26, 2012 | 07:09 PM
SinisterC6's Avatar
SinisterC6
Speedy
sort of... I text you
To external waste gate dump
Old Apr 26, 2012 | 08:37 PM
RMS-MAN's Avatar
RMS-MAN
http://www.youtube.com/watch?v=8KheP7e43KI
Here is a vid of mine with open WG dump straight down at rear of bumper. It's a Leer Jet sound and i am addicted to the sound. Also has a 4" downpipe with a 4" glasspack muffler for diesel trucks.
Old Apr 26, 2012 | 08:41 PM
RMS-MAN's Avatar
RMS-MAN
And here it is on dyno.
http://www.youtube.com/watch?v=dMd-H...e_gdata_player
Old Apr 27, 2012 | 09:32 AM
Abirli's Avatar
Abirli
thats nasty!
