C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best rollbars
Old May 1, 2012 | 01:40 AM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Default Best rollbars
It seems everyone always wants the best, so this is it.
If you are needing rollbars to race, place your order soon, so you don't miss this opportunity.
To keep the price low, I only fabricate in batches of 10 after the 10th order.
These are specifically designed for C6 coupe and Z06 bodies and are the only ones on the market
that allow you to remove or reinstall in less than 15 minutes.
Fully frame mounted for maximum protection, including swing-out doorbars and all necessary hardware.
Available in either a 5 or 6 point configuration and powdercoated satin black or optional custom colors.
For more information go to www.hoxxoh.com
Old May 1, 2012 | 07:40 AM
walhan_qtr's Avatar
walhan_qtr
would like to see some more pics. especially behind the seats. Thanks
Old May 1, 2012 | 08:51 AM
GAMEOVR's Avatar
GAMEOVR
In for more pics as well. Behind the seats, where they mount to the frame and down on the floor board if you can thanks.
Old May 1, 2012 | 10:37 AM
robertaj's Avatar
robertaj
can you still mount the top from the car in the trunk or no?
Old May 1, 2012 | 12:59 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Yep! Sure can.
Old May 1, 2012 | 01:14 PM
robertaj's Avatar
robertaj
Originally Posted by HOXXOH.com
Yep! Sure can.
not bad... and do you happen to know if you install the cage without the door sides are you still compliant to run under 11.5 at the track, or are the sides by the door needed?
Old May 1, 2012 | 01:21 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Until I get the patent pending approval for methodology, I wont be providing pics of the details. The Div 7 NHRA tech who does chassis certification wholeheartedly approved it. Because I have no control over the final installation , I can't guarantee that aspect will be approved.
The construction is done with the same NHRA approved methods and materials for rollcages that require certification (9.99 and quicker). There were no shortcuts taken to save time or money.
There are no rivnuts, rivets, glue, or backing plates needed. Everything attaches directly to the frame, not the composite floor, not the SMC in the hatch tub, and not the sheet metal panel behind the seats. It's been designed to provide real protection, not merely squeak by the minimum requirements.
Initial installation requires removal of seats, door and sill trim, dead pedal, and mufflers. Front carpet can be peeled back during the install and doesn't require full removal. Rear carpet can be slit and holes in the hatch tub floor can be cut from above. Estimated time to complete is 3 hours.
Also visit www.HOXXOH.com
Old May 1, 2012 | 01:52 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Glad you asked.
The rules for drag racing require a minimum 5 point rollbar, which includes the forward door bar. The doorbar is a swing-out style to allow easy entry/exit by pulling out a pin at the top. The doorbar can be completely removed in just seconds, by additionally pulling out the pin at the bottom. The length will easily fit in the cargo net for transport to or from the track.
NHRA specs for safety equipment are generally more stringent than others. Not all types of racing require 5 point bars. Some only need 4 point, some 6 point, and some just a harness bar or nothing.
Old May 2, 2012 | 02:20 AM
walhan_qtr's Avatar
walhan_qtr
Until I get the patent pending approval for methodology, I wont be providing pics of the details. Suffice it to say, a block welded to the rollbar that bolts to a block welded to the frame.
The Div 7 NHRA tech who does chassis certification wholeheartedly approved it. Because I have no control over the final installation (welding blocks to frame), I can't guarantee that aspect will be approved.
The attachment points are machined blocks that weld to the frame. There is a mating machined block that is welded to the bars. The construction is done with the same NHRA approved methods and materials for rollcages that require certification (9.99 and quicker). There were no shortcuts taken to save time or money.
can you email me pics?? I am seriously thinking about putting one on my other vette. I have the RSD 5point on my Z06 and I like it. but yours looks a little cleaner behind the seats. I cant just buy something without seeing full details.
my email is walhan_qtr@msn.com if its possible to send pics. if not its understandable....
Thanks a lot
Old May 2, 2012 | 10:37 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Thanks a lot
I'll post the pics here either tomorrow or Friday. I wanted to from the start, but was advised to wait.
I think you'll like it. Especially, that it can be removed so easily for everyday driving.
www.HOXXOH.com
Old May 3, 2012 | 05:03 AM
walhan_qtr's Avatar
walhan_qtr
www.HOXXOH.com
Thats great. i think it will help selling more of those kits. waiting for pics
Old May 3, 2012 | 11:04 AM
robertaj's Avatar
robertaj
www.HOXXOH.com
my et streets are in and going on this weekend... so no doubt ill get the boot from the track next time i go which means ill have a rollbar shortly there after lol
Old May 29, 2012 | 07:14 AM
walhan_qtr's Avatar
walhan_qtr
any updates??? I need to order a roll-bar...... do you have these in stock?? I kinda need one asap. might give yours a try.
Old May 29, 2012 | 11:15 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Update was posted as a new thread, but I'll bring it ttt for you.
Because these are not generic (one style fits all) I only build in groups when the orders of the several styles total 10 units. That keeps the costs down, but unfortunately doesn't allow for units to be completed and in stock.
Here's the link to the update thread.
http://forums.corvetteforum.com/c6-f...hra-legal.html
Old May 30, 2012 | 01:54 AM
walhan_qtr's Avatar
walhan_qtr
so how many do we have right now with pre-orders??? looks like I will end up with another RSD 5point as I cant really wait very long for this unless we are close??
To Best rollbars
