IAT mounting on Speed Density, FI
#43
Just wire it into the two iat wires.
#46
IF it is going to be SD then just weld a bung on the charge pipe before the TB and install it there.
Depending on if it is LS2 or LS3 you can look up the 5 wire pinout for either man and run the correct two to the sensor.
I like to use the LSA IAT2 sensor. You can take the break points and cure from an LSA tune for the IAT calibration.
#49
#51
Received 1,261 Likes
I put my iat on the bottom of the charge pipe just before the throttle body so it isn't seen from up top, it looks cleaner that way in my opinion
#52
I was also running dual meth and had the nozzles on top of the charge pipe just after the bend where it comes out of the intercooler... I never had an issue with it
#54
got any pix? i had mine down there before.. And was told that was to low in the charge pipe.. I would love to have them down there.. out of site out of mind
#55
Put the meth further back from the TB and the IAT right before the TBG in the charge pipe. This is better then putting it in the manifold when you have the room on an SD setup
#56
Can i I go under the radiator cover so u don’t see the meth lines? Or is that too far?
#57
#58
Only problem is at the bend will hit the cover. Have to figure out something. So bend or closer to tb but not before the bend. Getting a new 3.5 pipe made have to see what I got after I cut it to fit
#59
meth nozzles are on top, only the iat is on the bottom... this is the best pic I could find on my phone but you can see where the nozzles are... iat is as close to the throttle body as I could get it with the coupler installed
#60
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
I've got mine the same as neutron82.
Top view with meth nozzles:
IAT mounted underneath just before pipe coupler to TB:
