For those using a shortened Dewitts with their Centri setup.
What did your do about the gap left between the top of the radiator and the aluminum shroud. Right now mine is open and I believe it is contributing to excessive motor temps in stop and go traffic by allowing air from around the motor to recycle over top and back through the radiator. I will hit 225 in stop and go but drops to 189 when back to speed. This never happened with the factory unit.
