C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Procharger owners
Old Jun 4, 2012 | 08:29 PM
Hectorls1's Avatar
Hectorls1
Default Procharger owners
The stock D1SC with # 12 pulley. What problem have you had with this unit ? What upgrades would you recommend ? Thanks
Old Jun 4, 2012 | 08:36 PM
White_Lightning's Avatar
White_Lightning
there is no such thing as a 12# pully.. each pully will make differnt boost based on your motor/charge pipe/heads/intercooler/restriction in the air path.
maybe if you give a few more details you will get better answeres..
Old Jun 4, 2012 | 09:00 PM
1320IN9's Avatar
1320IN9
some more details would be helpful for us to help you.
Old Jun 4, 2012 | 09:13 PM
Detoxx03's Avatar
Detoxx03
What size pulley and mods do you have?
Old Jun 4, 2012 | 09:45 PM
Hectorls1's Avatar
Hectorls1
Here are the specs, this is not my car but one I'm looking into buying. Car will not be a track car at all more of daily driver fun car. Reliability is more important than RWHP.
Pulley is stock which is the 4.75"
Made 676rwhp and 616tq. TO THE WHEELs
ECS alky methanol injection
Dewitts radiator
Kooks stainless steel long tube headers and x-pipe with high flow cats
B and B bullet cat-back exhaust. Full 3" exhaust from headers back.
Old Jun 4, 2012 | 10:27 PM
Detoxx03's Avatar
Detoxx03
Dewitts radiator
I have the same size pulley on my car but no meth and I have a blower cam. It makes 7lbs so I figure that car should be making around 8-10lbs.
Old Jun 4, 2012 | 11:08 PM
nareg's Avatar
nareg
If its done right you shouldn't have any headaches.
Old Jun 5, 2012 | 08:44 AM
playtoy's Avatar
playtoy
Dewitts radiator
I had a similar setup on my car, D1SC with 4.25" pulley, Dual Nozzle Alky Control Meth, Dallas Performance Blower Cam, American Racing Headers, catted x-pipe and corsa exhaust which made 698 rwhp. I drove it with no issues for 2 years, only maintainence was changing the oil and the spark plugs. If the car is setup right you shouldn't have any issues.
Old Jun 5, 2012 | 10:46 AM
turbotuner20v's Avatar
turbotuner20v
Dewitts radiator
That sounds like a reliable combo. I run the 4.75" on a D1SC with a 4" intake (picked up ~2psi from less restriction) and my car makes 630whp at ~10psi with no meth and z06 manifolds/NPP exhaust.
I'd guess that car makes ~8psi and that's a strong HP number for the seutp. I'd check the meth tune to make sure it's not meth dependant, but that's all I would worry about.
Old Jun 5, 2012 | 11:41 AM
Detoxx03's Avatar
Detoxx03
To answer you original question though it should be fine as long as the install was done right and it has a good tune.
To Procharger owners
