I'm going to hook up 3 gauges to my 2007 Z06 with Edelbrock Supercharger . I need to know the following colors of the wires on the corvette .
1. Which wire is for dash lighting ?
2. Which wire is 12 volts hot, turned on and off with ignition switch ?
3. Which wire is connect from oxygen sensor signal wire to gauge ?
4. Which wire is 12 volts that maintains power during engine cranking ?
On the drivers side of supercharger there is a small plug , I watched a video on You Tube that states this is for a boost gauge , anyone hook there's up that way ?
Thanks In Advance .
