You will need different injectors. LS3 injectors are short, LS2 are tall. There will also be some other small items depending on what type of kit. Call either ECS, A&A, or whoever makes the kit so that you know you get all the parts and your build is not stopped.
EDIT, saw that you edited your post too. Call A&A, they should get you squared away.
Sounds good, I was actually going to buy your old kit from the guy that got it from you. I havent heard from him in a while, so im looking around again.
I bought a used recondictioned Vortec with A&A bracket.
It came off a C6Z and I had it installed on my LS2 w/o any problems.
3.8 pulley putting out 11.psi boost.
I had a 50/50 meth kit installed also..engine is all stock, no cam, no heads and no long tube headers...RWHP is 566/ RWTQ is 506
Get one and enjoy it.
