C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
fuel pressure problem?
Old Jul 12, 2012 | 10:25 AM
ultrvet's Avatar
ultrvet
Default fuel pressure problem?
I have a supercharged car with a boost a pump set-up
the pod gauge in my car always has read 60 to 61 lbs fuel pressure which I was told by the GM service guy is the correct factory pressure without the BAP increase - now it is only reads about 40 lbs -
so my question is whether it is likely the guuge is bad since the car probably wouldn't run and start normally if there is only really 40 lb fuel pressure?
I have not wanted to get on the car hard to see what happens in case there is really fuel pressure that low either due the BAP failure or possibly even the start of failure to the stock fuel pump - I assume the car would run lean in that cause and maybe do some real damage?
Any thoughts would be appreciated
Old Jul 12, 2012 | 12:12 PM
Le Mans Z06's Avatar
Le Mans Z06
Does it read 40 when the car is running, or when it is off?
Old Jul 12, 2012 | 12:28 PM
Deezee757's Avatar
Deezee757
I thought the normal psi was 40, and boost a made it 60?
Old Jul 12, 2012 | 12:31 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Normal is ~60#. I've seen mechanical fuel pressure gauges go bad and read low and I've seen EFPG's go bad too. I think before you do anything drastic it's worth verifying the pressure with a mechanical gauge on the rail.
Old Jul 12, 2012 | 01:04 PM
Deezee757's Avatar
Deezee757
Thanks! Learn somthing here every day. I'm happy I added one on the rails even more now.
Old Jul 12, 2012 | 01:08 PM
5 Liter Eater
St. Jude Donor '11
So you already have a mechanical on the rail in addition to the electronic gauge on the pillar? Easy check then.
Old Jul 12, 2012 | 03:23 PM
Deezee757's Avatar
Deezee757
I do the OP doesn't. Sorry for the thread jack.
Old Jul 12, 2012 | 03:59 PM
5 Liter Eater
St. Jude Donor '11
Oic
Old Jul 12, 2012 | 04:17 PM
old motorhead's Avatar
old motorhead
When the BAP kicks on, mine goes up a pound or so over 60.
Old Jul 12, 2012 | 04:49 PM
Motorhead-47's Avatar
Motorhead-47
At idle you should have 55-60psi. Put a mechanical fuel pressure gauge on the schrader valve on the front of the driver's side fuel rail and see what you have. Anything less than 55psi and you need to start looking for where the problem is. 40psi is not enough.
Old Jul 13, 2012 | 10:37 AM
ultrvet's Avatar
ultrvet
Now the pod gauge reads 0 so obviously either the gauge itself is bad or the wiring to it since the car is running fine
I guess my next step will be to determine what the problem is with that but in the meantime at least the car runs and I have learned a little bit about stock fuel pressure and how the boost a pump works
anybody out there have any deals on cobalt gauges - my air fuel one doesn't work either so I am down to just the s/c boost guage
Old Jul 13, 2012 | 11:56 AM
Deezee757's Avatar
Deezee757
Lethal racing was doing gauge/pods deals. Give them a call. You still could add FP gauge to the rail also. They are pretty cheap and no wires to run obviously
Old Jul 13, 2012 | 01:23 PM
ultrvet's Avatar
ultrvet
Thanks Deezee757 - I will check out Lethal
To fuel pressure problem?
