C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
NOVI 1500 max boost
Old Aug 7, 2012 | 04:27 PM
CYA-Vett's Avatar
CYA-Vett
Default NOVI 1500 max boost
How much boost can I get out of a NOVI 1500? I'm currently around 16psi.
Old Aug 7, 2012 | 06:03 PM
Unreal's Avatar
Unreal
Depends on heads,cam,exhaust,motor,etc.
Old Aug 7, 2012 | 06:28 PM
CYA-Vett's Avatar
CYA-Vett
Forged 364 stock heads, headers, etc...
Old Aug 7, 2012 | 08:03 PM
Slo-Poc's Avatar
Slo-Poc
Pulley setup?
Deezee757's Avatar
Deezee757
What kind of power do you make at 16psi?
Old Aug 7, 2012 | 08:38 PM
CYA-Vett's Avatar
CYA-Vett
670 through an A6 with 3,800 stall.
Old Aug 7, 2012 | 08:51 PM
ftf3rd's Avatar
ftf3rd
ftf3rd
forged crank, pistons, rods, etc
Old Aug 7, 2012 | 10:03 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
winters97gt made over 800 with the stock ECS kit (Novi 1500) on a built 402 on six ribs. With that many cubes I think boost was lower, like 12 or so. Before that I had the same kit and was making ~14# with the stock ECS pulley for 730/675 on my stock long block plus ECS blower cam with headers and meth.
Boost is somewhat irrelevant. What pulley do you have now?
Old Aug 7, 2012 | 11:28 PM
Deezee757's Avatar
Deezee757
Yea I'm right at 700whp with 12psi headers, cam, and meth, with lots of room to grow once I forge the internals!
I'm guessing your one pulley size down and no restrictor???
Old Aug 7, 2012 | 11:52 PM
5 Liter Eater
St. Jude Donor '11
14# on the LS2 was the stock ECS pulley (don't remember the size) with no restrictor. I was going to drop a pulley size and shoot for 17# but changed directions.
Old Aug 8, 2012 | 06:17 PM
robertaj's Avatar
robertaj
dont take this the wrong way but isnt that REALLY low?
I have 9psi and am running 655.5rwhp 630rwtq.... figure almost DOUBLE boost you should be like 800ish no ? Are auto's THAT much less? Maybe you need a better tuner?
Old Aug 8, 2012 | 06:54 PM
CYA-Vett's Avatar
CYA-Vett
I would guess with a M6 I would be about 700.
The motor is forged and built for boost, it has a lower compression, thus lower HP.
Looking for more, not that I need it, I just want it.
Old Aug 8, 2012 | 08:20 PM
Deezee757's Avatar
Deezee757
I think the last rough calculation I saw for drivetrain loss I saw was 17.3% for manuals and 23% for autos?
OP, to best answer your original question I'd call ECS. But please post what they say here!
Old Aug 8, 2012 | 11:33 PM
Drewstein's Avatar
Drewstein
You completely ignored cubes in that equation. Do you have same CI or more? Boost is only a measure of restriction.
What he should be asking is how fast can he spin the thing. If he still has room in the blower to spin it faster then there's the answer.
Old Aug 9, 2012 | 04:09 PM
VPR LOL's Avatar
VPR LOL
The blower will make power with a 3.125 pulley and a stock balancer. I made mid 800hp/800tq on a T-trim(novi 1500) with a 3.125 pulley and over 400 CIs. It also has a nice hit when you over spin it. Might not make power to 7000rpm, but my car ran pretty well with that blower.
Old Aug 9, 2012 | 04:16 PM
robertaj's Avatar
robertaj
looking further into his profile i see an ls2 looks like? I guess your right. I have an ls3.... didnt realize there would be such a big difference in power.
Old Aug 9, 2012 | 04:29 PM
Le Mans Z06's Avatar
Le Mans Z06
That doesn't matter, I make 676rwhp with headers/meth/ecs novi 1500 through an A6 on 12 lbs
To NOVI 1500 max boost
Old Aug 9, 2012 | 07:17 PM
Deezee757's Avatar
Deezee757
Yea and that's an a6, a manual would be over 700
Old Aug 14, 2012 | 06:33 PM
Drewstein's Avatar
Drewstein
What doesn't matter?
My point was to disregard the boost PSI because it's not a function of flow but of restriction.
Calculate out how fast the OP is spinning the blower currently and see if it can spin faster or is it maxed out.
Your numbers further muddy up the comparison because of the Meth. Comparing apples and oranges here.
Old Aug 15, 2012 | 09:10 AM
Le Mans Z06
I was stating that a LS2 vs LS3 doesn't matter, they both can make similar and great power through forced induction. When ECS did my install they had just did an identical install on a LS3 and I have a graph somewhere showing the differences, and it was about 12 peak rwhp difference. There were differences throughout the RPMs but it was very very minor. I was just trying to prove my point via my car/build that LS2s don't make a lot less HP than LS3s.
That is the quote I was addressing with my post.
