C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Catch can content
Old Aug 12, 2012 | 10:38 AM
383's Avatar
383
Default Catch can content
This is from 2 or 3 auto-x's in about 2 months and almost no street miles.
Its about 30% water and the rest is fuel smelling oil.
Has anyone else seen this much crap in such a short time?
Most is coming from the rear driver side valve cover.
Old Aug 12, 2012 | 11:09 AM
1VetteJocky's Avatar
1VetteJocky
Where did you install the return line? From the factory connect or someplace like the the oil cap ?
I installed mine from the factory connect but didn't tighten the clamp quite right and the hose came off. there was a lot of oil splattered in the engine compartment after just a couple days. Just got my catch can - will install it pronto. The water mix you see is because during initial startup there is a lot of moisture that comes off the engine and condenses in your catch can.
Old Aug 12, 2012 | 01:02 PM
ANGRY Z's Avatar
ANGRY Z
Wicked
Or.... And I hope not... You have a cracked sleeve, which allows coolant down into the oil to make a nasty milkshake. I speak from experience. Look at my albums.
Old Aug 12, 2012 | 02:16 PM
BLACK-10's Avatar
BLACK-10
that is normal. not only does it remove oil blow-by, but it removes moisture also
Old Aug 12, 2012 | 02:34 PM
383's Avatar
383
One vacuum before the TB one after and I T'ed both valve covers into one(I have a 2valve catch can)
It just seems like a large amount of both to me.
To Catch can content
