C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
is clutch slipping
Old Sep 5, 2012 | 11:51 PM
1sc334's Avatar
1sc334
Default is clutch slipping
how do i know? Sometimes it takes a while to go into reverse unless i go into another gear first n wont let me go from 5th to 6th all the time do ranger methodcon fluid regular but have no remote bleeder so havent bled help PLEASE!!!!!
Old Sep 6, 2012 | 12:25 AM
winters97gt's Avatar
winters97gt
That isn't indicative of your clutch slipping. Having to engage the car in a forward gear to get in reverse happened all the time with my c5Z. Didn't happen on my tr6060. Having trouble going in to 5th or 6th might be another issue with the clutch/tranny. If it is slipping, you will know under full boost
Old Sep 6, 2012 | 09:27 AM
TRINIC5's Avatar
TRINIC5
Did you recently interfere with gear lever mechanism? There is an adjustment that may be require if you did and if not,the problem sound like the pressure plate is not comepletly releasing, usually when the clutch is partially engage it become difficult to get into reverse.
Old Sep 13, 2012 | 11:19 PM
SlingindirtM95's Avatar
SlingindirtM95
Sounds like a hydraulic issue not a clutch slipping. I would start with the slave
To is clutch slipping
