C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Piston Contact
Old Oct 4, 2012 | 12:48 PM
greerracing's Avatar
greerracing
Default Piston Contact
A while back my cam gear came off my camshaft and I started tearing the engine apart to see how bad the damage was. Overall i have seven bent valves, six are exhaust valves and one is a intake valve. The problem i am having is deciding how to fix the engine. I drained the oil and there is no metal in it so that is a good sign. There is small dents in the pistons but they are not very deep. I talked to an engine builder and he said to take emery cloth and take the lips off of the dents put a set of rebuilt heads on it and a new valve train and run it. Does anybody think that the pistons could explode from the boost or will the pistons be okay. I am running 12 pounds of boost right now also from a upp twin turbo kit.
Old Oct 4, 2012 | 01:09 PM
DSteck's Avatar
DSteck
Screw it. Sand the edges and run that thing.
Old Oct 4, 2012 | 01:20 PM
greerracing
It sounds like that is what i am doing after talking to everyone.
Old Oct 4, 2012 | 08:51 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
grab some 317's and turn up the boost!!!!
Old Oct 4, 2012 | 09:06 PM
greerracing
You and Dave think just alike with the heads. Im also going to put a custom cam in it, ls9 head gaskets, and arp head studs.
Old Oct 6, 2012 | 03:08 PM
carlrx7's Avatar
carlrx7
good idea, same setup i have.
-Carl
To Piston Contact
