C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Help! Hot engine coolant
Old Oct 27, 2012 | 05:55 PM
DocT's Avatar
DocT
Default Help! Hot engine coolant
Posted this in another C6 section, but it's slow over there. Here's the situation:
Driving home from son's football game, looked down and the engine temp (gauge) was zero...the DIC had XXXcoolant temp.
The oil temp is 140 per the DIC. I was appx 5 miles from my office, so I kept going with the thought that if the engine truly was hot/overheating, that the oil temp would begin to increase in temp...and it didn't at all. Got to office, and hoses all good, none super hot, no steaming...etc.
I checked the sensor. Fine. Even changes the sensor and still same thing.
I've recently had a 160 thermostat installed.
Any suggestions for next step?
Suggestions?
Old Oct 27, 2012 | 06:55 PM
turbotuner20v's Avatar
turbotuner20v
I'm not following... I wait till the oil temp is 150 minimum and coolant temp is 192 before I even go WOT. So if oil temp is 140, its just getting warmed up.
Old Oct 27, 2012 | 07:15 PM
DocT's Avatar
DocT
Sorry. I probably wasn't clear. Normal driving and then I get a 'hot coolant temp' sign on DIC. I check actual coolant temp and it says "'XXXtemp' turning a/C off". The actual temp gauge was pegged at ZERO. thought it may be a bad coolant sensor, so I put anew one in...and NO CHANGE. still the same isssues.
Old Oct 27, 2012 | 10:53 PM
Dragracer_Art's Avatar
Dragracer_Art
During T-stat replacement, I'll bet the system wasn't burped/purged properly and it probably has an air pocket in the cooling system.
Old Oct 27, 2012 | 10:59 PM
playtoy's Avatar
playtoy
^^^ my thoughts as well.
Old Oct 28, 2012 | 01:23 AM
cranky's Avatar
cranky
THIS
Old Oct 28, 2012 | 07:01 AM
DocT's Avatar
DocT
Interesting! Thanks guys. I'll take her back to the shop then to have them work ou the bugs
Old Oct 28, 2012 | 07:41 AM
EuroRod's Avatar
EuroRod
How long since the T'stat swap? Have you checked your coolant level? If it is air trapped in the system, it should clear up after several heat/cool down cycles, and the system require additional coolant. You may actually have to add coolant a few times before the system is fully purged of trapped air and the coolant level stableizes.
If this does not fix your problem, check the wires from the sensor. It could be an open circuit that is not sending info to the ECM.
Old Oct 28, 2012 | 09:13 AM
6Speeder's Avatar
6Speeder
This happens to someone EVERY fall after a 160 install. If you are taking it to a shop have them check the code thrown. It'l be a "coolant undertemp" code. Clear it, you're done.
Old Oct 28, 2012 | 11:55 AM
DocT's Avatar
DocT
It was either the sensor or just rearranging the wiring a bit...I was going to take her to the shop and drop her off for them to figure it out, and after driving it for 2-3 minutes everything started registering again. Took to autozone and they said it was thermostat issues, reset the code and we're good. Drove it for about 40 miles and everything's good to go! Thank GOD!
Old Oct 28, 2012 | 12:11 PM
Boat Racer's Avatar
Boat Racer
I hope you have found a solution to the problem. I had a similar problem after I had my OEM thermostat replaced with a 160 degree stat. I first replaced the temp sender and thought that I had the problem solved but it popped up again after a few days. I was getting a code PO128 which I was told meant that the coolant temp wasn't getting to the programmed temp setting as quickly as the computer thought it should. My tuner ended up disabling that code to resolve the problem. Good luck.
Old Oct 28, 2012 | 04:48 PM
RMS-MAN's Avatar
RMS-MAN
It's all in the tune. Seen this so many times on C6s with colder than stock thermostats.
Just disable the code P0128 and don't look back. Uncheck MIL box, and set to No Error Reported.
To Help! Hot engine coolant
