C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Belt slip
Old Nov 5, 2012 | 01:14 PM
whatcop?'s Avatar
whatcop?
From: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Default Belt slip
How are you guys tackling it?
This is my 2.38 pulley on my ZR1 from Lingenfelter. I notched it and the notches are wearing away. There was notches on the outer ribs too.
Old Nov 5, 2012 | 01:17 PM
Unreal's Avatar
Unreal
Hoping a DD direct drive fixes it. As for zr1 owners I dont think that will help.
Old Nov 5, 2012 | 01:36 PM
whatcop?'s Avatar
whatcop?
The direct drive would be the solid isolator correct? I already have that.
Old Nov 5, 2012 | 01:47 PM
Unreal's Avatar
Unreal
No, seperate drive belt for the blower and accessories. I believe zr1s already have that factory.
Old Nov 5, 2012 | 06:50 PM
whatcop?'s Avatar
whatcop?
The supercharger belt also drives the power steering and water pump.
Old Nov 6, 2012 | 09:11 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have not been able to hold a 2.3" pulley on any ZR1, dyno yes, real usage no.
We go with a 2.6 upper and an over drive balancer, they seem to hold.
Old Nov 6, 2012 | 09:34 AM
frc's Avatar
frc
Thats why I went with the 2.6.
Old Nov 6, 2012 | 11:43 AM
whatcop?'s Avatar
whatcop?
I would do that but the problem is I road course the car and so I can't run the OD balancer.
Old Nov 6, 2012 | 01:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Rules of your class?
Old Nov 6, 2012 | 03:44 PM
whatcop?'s Avatar
whatcop?
Nah I only do HPDE but due to it over driving the water pump and power steering it will damage them.
Old Nov 7, 2012 | 08:30 AM
DOUG @ ECS's Avatar
DOUG @ ECS
IMO 10% is not enough to make any substantial change in pump life, sure beats belt slip anyway.
Old Nov 7, 2012 | 08:57 AM
whatcop?'s Avatar
whatcop?
I agree that 10% isn't much, however one guy just commented that he is boiling his power steering fluid and he is stock.
Old Nov 7, 2012 | 09:38 AM
DOUG @ ECS's Avatar
DOUG @ ECS
I used to do that all the time with an under drive balancer on my NA C5, a lot of that has to do with how aggressive you are on track, alignment and tires used. I simply added a bigger PS cooler and viola, problem solved.
Old Nov 7, 2012 | 11:35 AM
whatcop?'s Avatar
whatcop?
Yeah I fried the one in my Z06 and ended up going with a turn one pump. I am not too concerned about the PS pump but more with the water pump.
Old Nov 7, 2012 | 03:04 PM
Kadorja's Avatar
Kadorja
can you smell the belt slipping. i think im having a belt slip issue but dont see any wear marks... just a funky smell thats not clutch or tires
Old Nov 7, 2012 | 04:15 PM
Quiky One's Avatar
Quiky One
There are plenty of guys running 10% overdrive balancers on all of the LS motors with the stock waterpump. The LS9 does have the powersteering pump on the same belt where the other's don't, but I would say you would be fine. What is redline on your car? Also, if you are that concerned about it, you could always buy a Meziere electric water pump and negate that issue...
Jason
Old Nov 7, 2012 | 06:39 PM
whatcop?'s Avatar
whatcop?
I don't smell anything but have really bad belt dust. This pic was before I notched the pulley. Look in the lower left behind the tensioner pulley and you can see all the black belt dust.
Jason
Redline is 6500. Do those guys road course or are they strictly drag and street cars?
If I am correct electric water pumps cannot provide enough pressure to keep up with the road course setting.
To Belt slip
Old Nov 7, 2012 | 07:10 PM
Kadorja's Avatar
Kadorja
Thanks for the reply. I don't have anymore belt dust (had a lot from the belt rubbing but not slipping) but I don't think its my clutch either. The car still puts down power like crazy. I guess tonight I'll have to check and see if my boost goes up all the way and see if my speedo goes up with the RPMs.
Next step is throwing on a 1/2" smaller belt for my setup. How did you notch your pulley?
Old Nov 7, 2012 | 07:28 PM
GIO-305's Avatar
GIO-305
This is the only guy that has belt slip with the ZR1. I just found out why
Old Nov 7, 2012 | 08:22 PM
whatcop?'s Avatar
whatcop?
Dremel baby lol
New forum rule: One must have a running corvette in order to be allowed to post.
