C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Engine Oil
Old Nov 12, 2012 | 05:15 PM
Rocket-Sc's Avatar
Rocket-Sc
3rd Gear
Default Engine Oil
I wanted to know what kind of engine oil should I put with a Ls2 superchargerd.
I mounted the kit Vortech V2, we say that the engine oil temperatures are not exactly low, because 'until now I have always put the 5w30 mobil 1.
And you think 'too much liquid? Or are there other compatible oil without causing damage to the engine?
Thanks...
Old Nov 13, 2012 | 07:34 AM
MrStick's Avatar
MrStick
I use either Mobil 1 or Royal Purple.
Old Nov 13, 2012 | 07:40 AM
inspector12's Avatar
inspector12
Hey just read the oil info posted in this section. If its not a racing specific oil or diesel oil your shooting yourself in the foot. The Goverment EPA had all the oil co remove a **** ton of the Zinc and Phosphate from the oils which are a couple of the major lubricating properties in oil. They couldn't remove as much from diesel oils because of there heavy loads they are under etc...
http://forums.corvetteforum.com/c6-f...-oil-tech.html
Old Nov 13, 2012 | 08:10 AM
speedraider's Avatar
speedraider
Mobil 1
To Engine Oil
