C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-force tune
Old Nov 28, 2012 | 02:19 PM
ttbestas's Avatar
ttbestas
Default E-force tune
I downloaded the tune from ecu with hptuners, just have no idea if it is original elderbrock tune or modified. Can someone check it for me, i can email it to you.
Other questions is about the water pump? near the horn it keeps working for long time when engine is switched off, is that normal?
Car has upgraded radiator, msd ignition and borla exhaust, stock headers.
Old Nov 28, 2012 | 08:50 PM
Motorhead-47's Avatar
Motorhead-47
What year model car?
The coolant pump relay is triggered off the EVAP solenoid circuit. Pretty normal for it to run for a couple of minutes after the engine is shut down.
Old Nov 29, 2012 | 01:21 AM
ttbestas's Avatar
ttbestas
Its 2007 auto, also how much vacuum you guys have on idle with stock cam and e-force? My mechanical gauge doesnt move at all..
Old Nov 29, 2012 | 07:16 AM
j_digi454's Avatar
j_digi454
I have exactly that setup and my mechanical boost gauge reads approximately -20" (vacuum) at idle.
To E-force tune
