Boost referenced Fuel system issues?
Are there any disadvantages running these fuel pressures on C6:
40 psi while decel
43.5 psi idle
53psi at 0 Vacuum
63 psi at 10 psi boost
Tanks would be dropped to install LPE in tank FPR block offs:
http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
I got the above values from scanning my car at decel, idle, 0 vacuum (ignition on engine off) and assuming 10 psi boost from blower at WOT max pressure.
My reasoning as most know, is to get injectors like SD 60's to still behave properly at idle/parking lot speeds, and still provide enough fuel up top, while upgrading your overall fuel system to handle the power.
This would mean that the Deka's would act like the following:
57 lb/h at decel
60 lb/h at idle
66 lb/h at atmospheric
72 lb/h injectors at 10 psi boost
(boost to fuel pressure within reason I know its not exactly linear)
Since these injectors dont do so well at 58 psi stock fuel pressure & low speeds, I'm certain they would do just fine if we could get the IPW above 1.5 at idle which using these values/pressures should be no problem.
To add to that, I'm thinking there wont be many issues with getting the correct injector data using boost reference, reason being because like on old LT1's we'd have the IFR table set to constant across the board (since FPR will vary with manifold pressure), and the voltage table would also be flat lined in reference to pressure delta, and only vary with voltage which is easy to figure out especially once you get these injectors into their linear sweet spot, which according to the injector data I found for them starts at 1.5 ms.
Not sure if I'm missing something, never had a boost referenced FPR but I'd gather it references vacuum for driving and boost at high demands.
Ofcoarse eventually I do want to get ID's or new Boschs, but I'd be upgrading fuel system as well, and for the time being I wonder if that could work, next year upgrade to some nice injectors once my pre-buy condo is built.
Also I read some regulators boost referenced don't compensate in vacuum but I think most of the nice units do, but I'll read into that a bit more.
http://www.injectordynamics.com/Stec...reArticle.html
Something like this:
http://performancefuelsystems.com/De...eRegulator.htm
BTW. Dave is the man! I've learned so much just by asking him questions here and there.
FWIW, my Aeromotive pump controller is screwed up and intermittently shuts my pump off. It has always been a piece of crap, which is why I'm just coding and building my own controller now that will blow it away. Should prolong pump life too.
Failing to do so will allow the factory regulator to just bleed the added pressure off into the tank. Now, before everyone jumps in and says, oh just add a check valve on the factory feed line. Well the problem with that is now your are entirely dependent on the external pump for all the fueling which most wont keep up standalone.
I imagine most people just go that route. I think there's something wrong with my Aeromotive controller as well. Sometimes the pump clicks after shutdown. It's like the pump is receiving pulses from the controller although the engine has been shut down. It's clicking at a variable rate of 0.5 to 5Hz, usually slowing down. Does it for some time and then it stops. Sometimes clicking is related to using fob buttons... The power and ground wires come from the fuse box and from the big ground (starter etc) below the fuse box. Then the control wire is from the pink wire at the original wiring.
I never liked the Aeromotive pump controller. That's why I'm ditching it in favor of my own setup. Pump speed scaled with boost? Yes please.
