C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
rear steam vent question
Old Jan 3, 2013 | 02:37 PM
turbotuner20v's Avatar
turbotuner20v
Default rear steam vent question
Does anyone know if there is a version of a front steam vent for any LS series motor that has a vertical port vs. this style that points to the front/rear when installed? Part number?
Old Jan 3, 2013 | 04:07 PM
ChevyDave's Avatar
ChevyDave
i'm posting this but if i totally misunderstood your question, i do apologize.
front coolant by-pass vent.. see item 306 (part number in list in orange on right)
http://parts.nalleygmc.com/showAssem...rimLevel=14233
f.y.i. entire list of all with coolant pass in list.. long but your answer is somewhere in this long list
http://parts.nalleygmc.com/productSe...nt%20by%20pass
Old Jan 3, 2013 | 05:21 PM
turbotuner20v
Kinda, I was trying to think of the best way to describe it. That looks like the standard steam port pictured in the image I attached (and what is currently on the front of my LS3).
I thought there might be a version for a truck or something where the steam port pointed 'UP' instead of 'forward', thus making it easier to use on the rear of the engine.
Old Jan 3, 2013 | 06:38 PM
playtoy's Avatar
playtoy
Why are you running it on the back of the motor??
Old Jan 3, 2013 | 08:28 PM
turbotuner20v
I will be running it at all 4 corners
Old Jan 3, 2013 | 09:17 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Not sure I get what your after. Something like this?
http://www.kurturbanperformance.com/...-adapters.html
Old Jan 3, 2013 | 09:39 PM
turbotuner20v
Found it... Part #307 from an '05 silverado 5.3
http://parts.nalleygmc.com/showAssem...modelYear=2005
See how it points upward
Old Jan 3, 2013 | 11:45 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
companies make adapter fittings so you can run custom lines like kurts units, or of course a turn key solution is always nice!
Old Jan 3, 2013 | 11:52 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I don't think that one will work. It points it toward the throttle body, Which would make it go towards the middle of your intake manifold in the back.
Old Jan 4, 2013 | 12:08 AM
turbotuner20v
Yea, it's hard to tell in that diagram how much it points back towards the middle of the valley. I thought if a -4 an fitting like the links above worked though, there might be enough space for that barb with some coolant hose and a clamp.
Old Jan 4, 2013 | 12:11 AM
turbotuner20v
Yea, I'm just looking at cheaper alternatives since the solutions people use range from home made and cheap to hundreds in an fittings and lines. I thought oem front and back might be a nice middle ground.
Old Jan 4, 2013 | 12:27 AM
ss2z06's Avatar
ss2z06
Just so I understand what are you trying to accomplish?
Old Jan 4, 2013 | 12:37 AM
turbotuner20v
Open up the rear coolant steam vents and 'y' it in with the front vents to run all 4 vs just the fronts with the rears blocked. The theory is that this helps rear cylinder temps.
Old Jan 4, 2013 | 01:31 AM
turbotuner20v
Even better, part number 307 from a 2009 Cadillac escalade has the port on the other side where the intake manifold bulge is smaller and it points straight up.
http://parts.nalleygmc.com/showAssem...modelYear=2009
Old Jan 4, 2013 | 08:18 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
The least expensive option may be these. With AN fittiings you can then direct them anywhere you want, and make them look much better than stock.
http://s41657.storefront-solutions.c...l.aspx?ID=3289
Old Jan 4, 2013 | 08:37 AM
turbotuner20v
That's the best price I've seen on those fittings. Buying 4 of them costs about the same as that rear steam tube from gmpartshouse though, then you would need to either buy an fittings or barbed fittings.
I'm just going to keep my oe front tube, add that upright rear tube for ~$25 and then run a line down the driver side fuel rail, Y into the front tube and continue that line forward to the original output location. Should be the cheapest option and look pretty clean.
To rear steam vent question
