C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Need help from EXPERTS
Old Jan 4, 2013 | 11:56 AM
lingenfelter200's Avatar
lingenfelter200
Default Need help from EXPERTS
Hi,
I have a problem in my C5 TT. I need someone who can diagnose this issue in the engine. I can't reach the required boost?! I did engine compression test and boost bleed everything was fine!! I increased the boost to 30 psi, but I couldn't see from that only 11 psi of boost??!!
What is the problem? No sounds in the engine nothing is wrong with it!!!
Engine spec:
427 CID
LQ9 Iron block
LS3 ported heads 245cc
LS3 intake
Garrett Turbos 76mm T3T4
compressor wheel 70
inducer 76
.63 A/R
cam spec:
Intake Duration: 235@.050
Exhaust Duration: 242@.050
Intake lift:.603"
Exhaust lift:.608"
LSA:114
Old Jan 4, 2013 | 12:01 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Boost controller solenoid maybe.
Old Jan 4, 2013 | 12:06 PM
turbotuner20v's Avatar
turbotuner20v
by boost bleed, do you mean leak down test?
Old Jan 4, 2013 | 12:09 PM
lingenfelter200
yes, I mean no boost leaks.
Old Jan 4, 2013 | 01:10 PM
turbotuner20v
I mean a leak down cylinder test. A friends supra had this issue where the boost wouldn't go over a certain level and he had a bad cylinder.
Or maybe it was boost increased but power stayed the exact same...
That'd be a pretty obscure reason, just popped into my head looking at your displacement out of a lq9 and the wear or blowby potential of that setup
Old Jan 4, 2013 | 01:26 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Waste gate stuck?
Old Jan 4, 2013 | 02:21 PM
mobius's Avatar
mobius
Do you have different waste gate springs, you could go to a stronger one to try it and eliminate the boost controller from the picture?
Old Jan 4, 2013 | 03:22 PM
slow ride's Avatar
slow ride
I'd be carefull with a 6.0 iron 427 since the pistons are so thin. If you have external wastgates check what springs are in them as said above. If you are using a low pressure spring (say 6 psi) and try to hit 20 psi the back pressure in the turbine housing can push the wastgate open. Backpressure can be higher then boost pressure+spring pressure (forces holding the gate closed), etc.
Old Jan 4, 2013 | 04:26 PM
Smoove's Avatar
Smoove
Either you have a boost leak, or your waste gate(s) are acting a fool-
Have you hit 30 before? And are now hitting only 11? Did you do ANYTHING to the car before/after this test?
Old Jan 4, 2013 | 10:24 PM
lingenfelter200
I did that leak down cylinder test, but let me do it again and I'll inform you soon.
Old Jan 4, 2013 | 10:49 PM
lingenfelter200
No, I haven't, but I did that from the boost control to increase the boost level to the max. I didn't do anything to the car after this test. sometime I hear misfire when I push much on the peddle!!
Old Jan 5, 2013 | 02:01 AM
Chevyrulz's Avatar
Chevyrulz
I had a tear in my waist gate diaphragm. Would only build 5psi was supposed to be 12
Old Jan 5, 2013 | 03:31 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Figured it was wastegate related. Internal wastegate?
Old Jan 5, 2013 | 07:39 PM
Chevyrulz's Avatar
Chevyrulz
No external.
Old Jan 8, 2013 | 04:30 AM
hefti2's Avatar
hefti2
What wastegate springs are in there? As a rule of the thumb you can only get about double to boost of the rated boost of this spring maximum, even with boost controller on full boost.
So if you have a 6psi spring you will only be able to achieve ~12psi..
So for 30psi you need AT LEAST a 15psi spring and that´s at 100% duty cycle of the boost solenoid or even directly connected hose from compressor housing.
What is your base boost w/o any boost controller hooked up to the WG at all?
Let us know then we can maybe rule that out or find it the root cause.
Gerd
To Need help from EXPERTS
