C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS upgrade?
Old Jan 10, 2013 | 06:55 PM
blacklsx's Avatar
blacklsx
Default ECS upgrade?
I have a ECS sl1500 kit with a paxton blower. Can I use a lager blower with the same brackets? What else would need to be changed?
Old Jan 10, 2013 | 06:57 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
You can upgrade to the YSI without any other changes, you would probably want/need to increase belt width though. Our base kit idlers are ready for an eight rib belt from the start, but depending on how much boost you wish to run you may want to go with a ten rib.
We have everything in stock if needed, give us a call tomorrow if you would like to discuss it in depth.
Old Jan 10, 2013 | 07:03 PM
blacklsx's Avatar
blacklsx
Thanks, I need a fuel system first. I'm building a short block this summer, I want to see what I can do with my current set up and max it out. It's nice to know that I can go up to a YSI incase this addiction gets worse. I need help.
To ECS upgrade?
