C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS2/3 con rods...how good?
Old Jan 22, 2013 | 06:44 PM
old motorhead's Avatar
old motorhead
Default LS2/3 con rods...how good?
I know any time anyone builds or rebuilds an LS2/3 short block, they ALWAYS do forged pistons and rods with the stock crank (unless shooting for 900+ and then the crank gets forged). GM uses stock LS3 con rods in their made for boost LSX376. They must know a little something about what they're doing. Aren't a huge percentage of the failures with f/i related to the pistons, lean AFR's, and too much timing? Or just the weak assed pistons just giving up after many high power cycles. Do the stock rods ever **** the bed without the piston on top of them failing first?
I'm about to put a short block together that won't see north of 700 rwhp. Are forged rods a waste at this level? I understand the "cheap insurance" arguement, but forged rods ain't necessarily cheap. I'd rather use the cash somewhere else. I'm of the opinion that if you buy all the cheap insurance available, you're going to "insure" that you're going to have an expensive short block. Overbuilt is over spent if you don't need the super parts. Your thoughts appeciated
Old Jan 23, 2013 | 12:28 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I would think the stock rods would be good for 700 assuming its not going to be a high rpm build. If keeping them I would consider getting them set up with some arp rod bolts.
My LS2 has gone for a while now on the stock short block with 615 rwhp and never had an issue.
That said, I am going with caillies ultra billet rods in my build, just for insurance.
Old Jan 23, 2013 | 12:47 AM
turbotuner20v's Avatar
turbotuner20v
I've never heard of a rod breaking before, but usually people don't want to try it when they buy or build a motor (myself included)
Old Jan 23, 2013 | 07:09 AM
old motorhead
Think I'll upgrade the bolts for sure. I don't spin my motors much over 6250. Should be OK. I see what some of the boys on the LS1 tech site do with boost on stock short block 5.3L junk yard motors. Amazing stuff. Of course, when they grenade one, they're out a whopping 500 bucks for replacement. I think the stock LS2/3 rods are tougher than the 5.3L rods too.
Old Jan 23, 2013 | 10:53 AM
NormWild's Avatar
NormWild
Don't think I've ever heard of a rod failure on the LS2/LS3, its almost always a piston that takes a dump.
Old Jan 23, 2013 | 12:07 PM
slow ride's Avatar
slow ride
The biggest issue I see is using a stock rod with a better bolt is the chance it will need resizing on the big end. I know some say you can just run them, but it's not the right way to do things. For close to the same money you can get Scat I beams with 7/16th standard arp bolts. Some guys have really pushed these rods and you can get them in 6.125/.927 so you can use more common aftermarket pistons.
Old Jan 23, 2013 | 12:08 PM
turbotuner20v
yea, and I think the LSX376 pistons are no longer sold seperately. I tried to go this route w/ my build, but could only find 4 in the entire US. They were the only pistons designed to fit the stock rods w/o modification I think.
Old Jan 23, 2013 | 12:24 PM
Detoxx03's Avatar
Detoxx03
I wouldn't want to find out if I'm building the motor anyway.
Old Jan 23, 2013 | 02:35 PM
BADZ's Avatar
BADZ
Stock rod bolts are your weak link and all stock rotating assembly...
Old Jan 23, 2013 | 03:02 PM
old motorhead
Didn't add extra machine shop charges into the equation. What do the Scat rods cost?
Old Jan 23, 2013 | 03:34 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Use a really good h-beam - callies or molnar
cost 560-600
prefer the molnar with their asymmetrical threads....same technology as carillo rods
Old Jan 23, 2013 | 03:53 PM
slow ride's Avatar
slow ride
http://store.hkracingengines.com/pro...products_id=62
Just one place to buy them. I'd use these all day over stock, but yes there are better rods out there. I'd say they are a bang for the buck champ
Old Jan 23, 2013 | 04:49 PM
Unreal's Avatar
Unreal
I thought I heard of a few PD/Turbo guys bending rods around 800hp. Centri guys can get away with a bit more because of the lower torque.
Old Jan 23, 2013 | 05:00 PM
Fiss's Avatar
Fiss
1. Why even build the motor if you arent going north of 700rwhp? A lot of people have made that much on the stock ls2/3 bottom end.
2. Why even build the motor if you arent going to upgrade some of the bigger items like the rods?
Consider buying a meth kit for a little more safety until you feel like building the motor up all the way. I just couldn't see myself doing R&R + replacing just the pistons and not doing the rods.
Old Jan 23, 2013 | 05:39 PM
Detoxx03's Avatar
Detoxx03
Spin that thing way past 6200 also.
Old Jan 24, 2013 | 01:25 PM
old motorhead
If I add ARP bolts to my stockers and even a little machine work, these pecil out way better. Had no idea an LS anything connecting rod was available forged for this price....and they come with ARP bolts. The motor that I'm building is an LS2 that's been sitting in my barn since '06. I wouldn't feel comfortable using it without freshening it up. Plan is for it to go in the wife's '69 Camaro. Add PD blower, mild cam, and bolt ons. With 10 psi on tap, we shouldn't need to spin it to the moon to be a fun ride.
Goal is a reliable driver that she can enjoy, yet be one of the fastest streetable Gen 1 Camaros around. With even a good running big inch gen 1 big block, they can't hold a candle to one with a well built blown gen 4 LS motor. I have some neighbors that have done the gen 1 to gen 4 swap and they say it's not too bad.
Old Jan 24, 2013 | 01:41 PM
slow ride's Avatar
slow ride
It's actually a SBC rod, but will work fine with most aftermarket pistons. The difference is that the SBC rod will have some offset in the small end where a ls rod is stright up. It's a very small amound and and you just want to check clearance at the piston. Keep in mind that running a .927 pin rod will open up piston selection a LOT.
I'm either a all in or do it on the cheap type of guy. Heck the stock rods with stock bolts might even be good enough for you, but I'm not sure what level you will be happy with power wise so.... You might need to have something done on the aftermarket rod also so you can't rule that out either.
Old Jan 24, 2013 | 02:09 PM
old motorhead
If I remember right, the 406 small block that's in her car now has Scat rods. I don't remeber the lenth. Plan to sell that engine complete though.
Old Jan 24, 2013 | 03:24 PM
TRINIC5's Avatar
TRINIC5
Maybe you guys just started posting and reading on here because in October 2011 I broke a stock rod in my LS3 and the result was not good, well lets just say I have a complete new 416c forged motor now.
#7 Rod broke and made a small hole for the piston to pass through the block but 7 pistons,7 rods, the cam and all the lifters are still like new, the motor had 2k miles on it and was making 738rwhp with a Procharger DISC.
To LS2/3 con rods...how good?
