had to make injector brackets anyone else?
Jan 23, 2013 | 09:02 AM
to run long injectors on ls7 intake with fuel rails?
nobody could source my buddy the right brackets.
anybody else have same trouble?
Jan 23, 2013 | 09:11 AM
Is that driver fuel rail going to clear the firewall at the back..?
Jan 23, 2013 | 09:33 AM
this happens to be for an f body, the answer for a vette i have not tried.
i have fuel rails on my z and the previous owners set up was crushing into the firewall so i changed to a different fitting and now clears easily (tho i run short injectors)
Jan 23, 2013 | 11:34 AM
Yes. Had my machine shop at work make me some nice billet aluminum adapters.
Jan 23, 2013 | 11:40 AM
If it's a -8 an fitting and a -8 90 degree hose end coming off the driver side it will not fit. You will have to cut some of the fiberglass on the Vettes unfortunately.
Jan 23, 2013 | 11:46 AM
i believe i used this one without any cutting on the vette
Jan 23, 2013 | 11:50 AM
Yeah that setup definitely works, but if someone uses a straight fitting with a 90 hose end it won't fit.
Jan 23, 2013 | 03:25 PM
Why not use short injectors?? I got ls7 stock height injectors. Used Aeromotive rails. Bottled right down. Wasn't willing to cut the firewall.
Dave. Where did u get the -8 to 6 elbow??
Jan 23, 2013 | 04:51 PM
I used an aeromotive banjo. Fits great and no cutting. -8 ORB to -6 banjo they sell.
Apr 30, 2014 | 03:14 PM
Apr 30, 2014 | 06:17 PM
St. Jude Donor '09
