C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Built a custom Stand-alone
Old Feb 18, 2013 | 04:20 AM
lilmiller74's Avatar
lilmiller74
Default Built a custom Stand-alone
I decied I was going to keep spraying my car so I built a custom stand alone for it. I finished it up today, I am going to run c16 in the stand alone and havent decided yet if im going to stay with the 150 shot or jump up to a 200 shot. I have a harris speed works plate and my car is an 05 vette with ls3 heads pat g cam and bolt ons and stock bottom end. Here are a few pics of the stand alone.
Old Feb 18, 2013 | 07:37 AM
TRINIC5's Avatar
TRINIC5
I must admit it is standing alone, enjoy it and hope it don't stand alone for long.
Old Feb 18, 2013 | 04:47 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Who did the welding?
Old Feb 18, 2013 | 11:10 PM
lilmiller74
I did, it was my first time in a few years welding aluminum and i had the wrong size filler rod. I had to cut it and shorten it and o had 1/8 inch filler rod and it looks much better.
Old Feb 19, 2013 | 08:43 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Still not bad. A lot better than I can do, lol
Old Feb 19, 2013 | 09:49 AM
lilmiller74
Thanks man. Here is the bottom that i had to redo and i had the correct size filler rod.
Old Feb 19, 2013 | 10:40 AM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Good work!
How much fuel does it hold, where are you going to mount it and what tells you how much fuel is remaining?
Old Feb 19, 2013 | 11:53 AM
lilmiller74
It holds half a gallon and im going to mount it in thr battery tray..as far as fuel level right now im just going to always fill it yo before i leave.
Old Feb 19, 2013 | 12:18 PM
ShaneFap's Avatar
ShaneFap
Very nice!
I always feel if you are wanting to spray over 150 its best to jump to a standalone.
Also one great thing about a standalone and race gas is you can keep running the same shot(example of 150) and run more timing due to the better gas.
Old Feb 19, 2013 | 02:35 PM
lilmiller74
Thats was what i was thinking if doing is just staying on a 150 shot and putting timing back in so i can add power and not risk much more.
Old Feb 20, 2013 | 10:16 AM
lilmiller74
Here it is just placed in the battery box, it fits perfect!
Old Feb 20, 2013 | 11:12 AM
marine&hisvette's Avatar
marine&hisvette
I would either cerimic coat those headers or heat wrap and wrap a heat shield of some sort around the fuel cell, or get some steel flasking and make a little fire wall between the fc and ac lines.. Paint it black of course. It gets hot under that hood
Old Feb 20, 2013 | 01:08 PM
4DRUSH's Avatar
4DRUSH
What's your plans on the vent line?
To rear of car?
Rollover valve?
Filter to keep dirt out under vacuum?
Old Feb 20, 2013 | 02:14 PM
lilmiller74
Its just going to be vented to the ground.
Old Feb 20, 2013 | 03:52 PM
4DRUSH's Avatar
4DRUSH
I would at least cap the vent line when that system isn't in use.
Old Feb 20, 2013 | 05:29 PM
lilmiller74
Its going to have a hose on it going to the ground, it's not going to stay like it is.
To Built a custom Stand-alone
