C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Question p1sc on ls3
Old Feb 28, 2013 | 09:45 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
Default Question p1sc on ls3
What's the most power I can make with this charger set up?
P1 procharger 10psi
meth
1 7/8 B&B headers
off road x pipe
B&B bullet axel back exhaust
NGK colder plugs
180 thermostat
M/T ET2 305/35/19
Old Feb 28, 2013 | 09:48 PM
Detoxx03's Avatar
Detoxx03
Lots of variables to into answering that. Why not start with a minimum of a D1SC?
Old Feb 28, 2013 | 09:52 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
Failed to find the kit for the ls3
Old Feb 28, 2013 | 09:58 PM
Detoxx03's Avatar
Detoxx03
When you look for the kits the P1SC is the standard blower. There is an option to upgrade to the D1SC and its fairly cheap compared to buying it later. With those mods it should get you to around 660-700.
Old Feb 28, 2013 | 10:03 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
That's not bad power! What can the ls3 handle like 750?
Old Feb 28, 2013 | 10:17 PM
Detoxx03's Avatar
Detoxx03
That's really subjective and up to the tune and fueling. The D1 will have room to grow where the P1 will run probably be done in that range.
Old Mar 4, 2013 | 01:08 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
Their is some talk of my stock fuel pump and 50lb injectors holding me back. the meth not being able to get me where i need to be!
Old Mar 4, 2013 | 01:13 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
a shop around here says i will only make 560ish? I made 500hp on 6psi with just an axel back exhaust! and im adding the 1 7/8 headers and 4 more psi of boost and meth
Old Mar 4, 2013 | 01:29 PM
Detoxx03's Avatar
Detoxx03
I would go with bigger injectors for sure. I have a 80lb FIC injectors on mine with meth a a BAP and my duty cycle is at 55%.
Old Mar 4, 2013 | 02:45 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
so you think i will need bigger injectors for sure i was hoping to get it tuned this weekend.
or do you think setup will be able to keep up with the boost? i have a friend coming down this weekend and i would like to have the car running good! i was hoping to get around 630 on stock fuel pump and 50lb injectors with meth. think i would be close?
Old Mar 4, 2013 | 02:55 PM
jon6.0's Avatar
jon6.0
It will be close. Be ready to put bigger nozzles in for your meth.
Old Mar 4, 2013 | 02:57 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
ok.. and what would it be best to run mix or straight?
Old Mar 4, 2013 | 03:03 PM
Mike_0715's Avatar
Mike_0715
Cruising
You will be looking at prolly about 550hp give or take a few
Old Mar 4, 2013 | 03:16 PM
Detoxx03's Avatar
Detoxx03
I run 100% meth. Get it tunes as is and see what your duty cycle it.
Old Mar 5, 2013 | 07:27 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
Where did you order your 80lb injectors and BAP from?
Old Mar 5, 2013 | 07:49 PM
Detoxx03's Avatar
Detoxx03
Injectors came from FIC (fuel injector connection) and I have a kenne bell bap
Old Mar 5, 2013 | 08:15 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
thanks for the info
Old Mar 5, 2013 | 08:59 PM
J3T_LAG's Avatar
J3T_LAG
Cruising
what amp is your boosta pump?
is it on a stock fuel pump?
is it ok to use the 40amp on a stock fuel pump?
To Question p1sc on ls3
