Those who have AeroForce Interceptor please chime in
I just installed a AeroForce Interceptor gauge. I would like to know how you have set yours up. What do you monitor? What sensors did you use? How did you install the sensors. Thanks for the feedback.
Fuel pressure with their FP sender, boost with a DPE 2.5 map, KR and IAT.
Afr with their sensor add-on, boost with a 2.5 bar map sensor, fuel pressure with their sensor add-on, iats, and pretty much anything else i want, mostly the fuel pressure and boost.
I pipe my fuel pressure and wide band into the analog inputs. My tune is set up for 2.5 bar SD so I already get boost via the built in boost PID. I have the annunciators set up to alert me if: BOOST > 5# AND AFR >12:1. I usually have KR and IAT or KR and fuel pressure displayed.
I ran 2 interceptors and a standalone. No issues until I spliced a window valet and dashtronix into the can feed. I think it was overwhelming it. Had to remove them eventually. Just a heads up if you add to it later
Just run a pressure line to it and +5v and ground. Mount it anywhere you want.
Sure. Any vacuum/boost line will work.
I'd like a KR alert too but I have to use both annunciators for boost and AFR triggers.
There is no audible alert. It turns the LED's on that would normally be used for a shift light. So big red shiny LED's staring me in the face if the meth fails or something else goes wrong.
