C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Trans temp ?
Old Mar 8, 2013 | 10:34 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Default Trans temp ?
Just got the car back from an A&A SC install. I have an A6 with a 3200 stall as well. In 35 degree weather and very minimal spirited driving (NO traction) I saw trans temps as high as 217. What will it be when it's 85 out and I'm pushing it? Is a good trans cooler required? If so where can I stuff it? That inter cooler took up a lot of room down front.
Old Mar 8, 2013 | 11:26 PM
jon6.0's Avatar
jon6.0
http://forums.corvetteforum.com/c6-t...on-cooler.html
Old Mar 9, 2013 | 12:05 PM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
Yes, a good aftermarket cooler is practically a must...especially with a higher stall on top of a s/c. In 35* temps you should not go over 180-185 on trans temps even after pushing it a bit.
Try a search in the Tech & Performance section for info on location of the cooler.
Old Mar 9, 2013 | 12:14 PM
Le Mans Z06's Avatar
Le Mans Z06
Yeah, definitely a must. Even with the Z51 package my car saw high temps without getting on it during the summer with a stall and blower setup.
Old Mar 9, 2013 | 04:44 PM
NSANEC6's Avatar
NSANEC6
Yes in my experience and research any shop that actually knows what they are doing will tell you that you definitely must have an aftermarket tranny cooler on a s/c and stall build.
Old Mar 10, 2013 | 06:24 PM
Atomic C6's Avatar
Atomic C6
This is a must not a should!
Old Mar 10, 2013 | 08:31 PM
brodyscorvette's Avatar
brodyscorvette
I've had good luck (and know others who have too) with running one large or two smaller coolers without running through the radiator. IMO if you're getting over 125 degrees when ambient is 35 you gotta do something ASAP. I never saw 170+ with a big stall in a 4700lb truck. And that's beating on it in 100 plus degree heat...
Old Mar 10, 2013 | 09:15 PM
speedraider's Avatar
speedraider
the shop that installed your blower should have told you to put a cooler on. Go somewhere else, I wouldn't trust them for ****.
Old Mar 10, 2013 | 11:20 PM
NSANEC6's Avatar
NSANEC6
If I had only known this back then.......
Old Mar 10, 2013 | 11:26 PM
jon6.0's Avatar
jon6.0
I kept my trans temps at 160F-180F when I was running a TH400 and 5200 stall in my 05 GTO. I was using a huge 48,000 GVW cooler to get it that low.
Above 220F is getting into too hot and above 250-260F is very bad.
To Trans temp ?
