C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
External pump + oem, return considerations.
Old Mar 21, 2013 | 08:05 PM
BoosterClub's Avatar
BoosterClub
Default External pump + oem, return considerations.
I am thinking now of just using the OEM pump with regulator blockoffs and an external. But with this setup the return will be in the tank rather then the OEM sump.
I don't imagine that them stock pump would outflow the speed of the gravity feed + siphons, but it concerns me a little to not give it consideration.
Those using this setup, is your return plumbed into the sump, or not at you have no issues?
For those unsure what I am referring to, normally the "return" goes right back into the oem sump that is in the gas tank, so the only gas actually "lost" from the sump is that consumed by the engine. The sump has a small (1/4-1/2") flapper gravity feed on the bottom, once the gas is lower than the top of the sump, that is that is the only way the sump is filled (besides the passenger and under sump siphon). With the return no longer plumbed into the sump, the pump is actually pumping full flow out of the sump, without the excess being returned to the sump and could theoretically flow faster than that flapper and the siphon.
Old Mar 21, 2013 | 08:40 PM
turbotuner20v's Avatar
turbotuner20v
No external return system I've seen has ever taken that into consideration. I wouldn't worry about it or trying to get a quality submersible hose for a custom return to the bucket.
Old Mar 21, 2013 | 09:14 PM
BoosterClub
Funny, I was looking at your thread and was thinking of PMing you. Rubber submersible hose is surprisingly expensive, but for the price you can actually just use a quality stainless/PTFE hose.
To External pump + oem, return considerations.
