C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Overheating
Old Apr 5, 2013 | 02:44 PM
LethalTT's Avatar
LethalTT
Default Overheating
A&A supercharged dewitts radiator. Out and about last night car hit 260 when I got home. I immediately turned car off. No coolant in oil. Topped off with water and wetter fans are running. Bled the sytem. Top hose won't get hot. Jumps to 220 really fast. Thermostat or waterpump? Either got to take the supercharger off. FML
Old Apr 5, 2013 | 04:54 PM
carlos@redline-motorsports's Avatar
0carlos@redline-motorsports
Former Vendor
It's probably going to be worse than that. You may have a blown head gasket. See if it will hold temp with the radiator cap off idling in the driveway. If it does and keeps belching, you got a blown head gasket. Seriously doubt it's the stat or the waterpump if the car gets driven regularly.
Old Apr 5, 2013 | 05:16 PM
LethalTT's Avatar
LethalTT
What do you mean hold temp? So take cap off run and if temp raises to 220-up and belches then blown head gasket?
Old Apr 5, 2013 | 07:53 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Sounds like you have air in the system. take the top hose off the resoivour and blow in the nipple on the resivouir itself ( you can use an air compressor, just turn it down to 10 psi). the level of the coolant will go down as it forces all the air out the hose that is disconnected, eventually coolant will come out of that hose as well, when it does, it is good to go.
-Carl
To Overheating
