Fuel pressure dropping after warming.
Base atmosphere fuel pressure @ 40psi. With the car cold and off running the fuel pump it obviously reads 40psi. Just started and cold, it idles around 35 psi (only about 8 inches of vacuum so this is correct).
Once its been running for 10-20 minutes and is warmed up I lose about 5-10PSI of fuel pressure. With the car off and hot, run the fuel pump and I get around 32psi (should be 40), car on and idling around 28 (should be 35).
Wait an hour for car to cool and test again, pressure is back.
Things I know its not;
Not a lack of flow or dying pump, in all these examples the external wasn't running, switching it on and tripling/quadrupling the flow and there's no change in pressure. There are check valves in place. Also voltage is appropriate.
Not a rip in the regulator diaphragm, that would cause an increase in pressure at idle and not explain the loss at atmospheric with the car off where the diaphragm doesn't do anything.
I don't believe it is the fuel getting hot and vaporizing either, only the oem pump was run while the car warmed up, so there was very low flow and low heat absorption. I am waiting on a fitting that will let me siphon some fuel off the car while running to test the temperature though.
Where are you getting your vacuum/boost reference? Does your vacuum change from cold to hot?
Runs normal around 50psi w/ vacuum on regulator, then suddently drops 20psi of pressure after a while. Restarting the car resets it temporarily. This is on E85 with 1500* heat wrap on all engine bay fuel lines, but with regulator after the stock fuel rail.
I first noticed my issue after making several WOT pulls for tuning and testing (hobbs turned on external pump), the previous ~300 break in miles never saw the issue (but some of those miles were hood off, and it was winter up here). This lead me to believe I damaged the stock pump by back flowing into it w/ my external and no check valve.
For now I just run my external on a switch and it works fine to supply all the fuel my car needs, and when I need to do some other maintenance I will drop the driver tank and replace the pump and add a check valve.
It sounds like you have check valves in place already though, so I'm interested to see what you find the issue to be since I may be going down the wrong path and may still have the issue when I'm done
*ah, I just saw the part where turning on your external doesn't change the pressure... for me this jumps my pressure up to ~58psi, actually 8psi more than when just the stock pump is running. That probably points more to a dying stock pump for me and for you, not sure...
Im thinking of remote mounting the sensor somewhere cool.
When I say 5-10 psi drop I'm talking about effective pressure, not actual pressure. You SHOULD have a drop in actual pressure as the car warms up and vacuum increases, but your effective pressure should remain the same.
I just hooked a mechanical gauge to the fuel rail with a hose and ziptied it to the wiper. so i had both working, went for a drive and it showed 5-6 psi diff.
Im glad i now have a Z06 pump but wish i had checked it first with the mechanical gauge.
Raise your base pressure. That regulator is probably not happy there. The spring is probably barely doing anything at that point and is so extended it is relaxing too much with heat.
When you say the spring is "barely doing anything" Are you talking about that pressure setting or at that flow rate? Because even after switching the eliminator on the pressure stays low. At that point, presumably, the plunger would have to open and compress the spring more.
I have an a1000 FPR I can try as well.
What I mean is for lower pressures, you're extending the spring inside of the regulator. If it extends too far, it can easily fall out of an effective range and become softer with heat to the point it allows fuel to pass through at a lower pressure.
The problem I have with the orifice size is that that would also be affected when the extra pump is turned on and volume increases, as the regulator then has to open more to allow it to bypass (thus compressing the spring more). So if that were the case you would expect a change in pressure.
If you're saying the base fuel pressure needs to be higher that makes more sense, but it's rated from 30-60psi and the rest are 40-75, so switching wont help. So I'm basically screwed, and that doesn't really help. And also again, you would expect when the flow increases for the pressure to change as the spring is compressed to bypass the extra fuel.
Not trying to shoot you down, I just can't isolate it as the problem without understanding why you say that.
Like I said I will consider it and try it, but I would have like to isolate it another way other than raising the pressure as that will **** off the tune.
Do you want me to mail you my mechanical gauge?
Or you could duplicate the problem then wrap an ice cold towel around the regulator to see if the pressure will rise back up.
Tomorrow or early next week I'm going to test the hell out of it, I'm going to hook in, along with the electronic, 2 additional (different style) mechanical gauges, siphon fuel when hot and measure it's temp, try raising base to 50 when hot then let it cool down and test again (that way I don't have to drive it @ 50), then try the a1000 regulator I have. Throw the cold pack idea in there somewhere too.
If none of that manages to resolve it, I will go hang myself.
