New Fuel System Idea
Also, I doubt that pump will handle 1200whp on its own.
Why would you tee the factory pump into the return line? That makes no sense.
There is no "upstream" and "downstream" pressure. The feed into the regulator is DIRECTLY connected to the output of the regulator to the fuel rails. NOT through any sort of orifice or limiting device like you seem to have decided in your head.
Pressure is regulated by a variable orifice that simply bleeds off excess pressure into the return line. It is partially open the entire time your fuel pump is on. It closes some when there is a higher fuel demand or higher targeted pressure from boost. It opens some when there is a low fuel demand or low pressure targeted from vacuum. It is not inline with the supply and output lines, it is teed in, it does not backup pressure on the supply line in order to effect a change in output pressure.
Regardless of how open or closed the orifice is pressure before and after the regulator are nearly identical. The only variance that may occur is from the restriction of the lines themselves. This is negligible in a system with recommended hose sizes for the flow.
I know it's probably really hard for you to wrap your head around these concepts, but try and actually go do some reading if you still don't get it instead of replying with some half cocked rant.
What I replied to was your comment that it's the ONLY way you should install a regulator and why doing it the other "wont work". Which was completely wrong and inaccurate.
You're simply wrong, but go ahead and dig yourself deeper and try to explain the bolded explanation.
I've bench tested the system at 20 psi and the pump works just as good at 20 as it does at 60 psi, just an fyi
Stock form it wont work because the stock regulator on the PASS side will close, but you take that regulator out and replace it with an LPE block off and you can run low pressure no problems.
Also... on side note, the stock pass regulator does control pressure 100% as well as the driver's. (example, with LPE block off on pass side, the system will NOT hold any pressure with pump off since it is a static fixed block with holes, so starting your car will take a few more cranks which is okay)
Pump feeds a bucket where the filter sits in the stock fuel module, that bucket then has a fitting that runs to driver's side regulator, and another fitting that runs directly to passenger side regulator. Both regulators are preset to 60 psi or so.
http://www.lingenfelter.com/mm5/merc...=#.UYE980qRd8E
Ya there is no need to install the block off plates unless you are wanting to go to a boost referenced fuel system.
However, the pas regulator doesn't really "control" pressure, since the siphon jet is a very small orifice, very little flow is able to actually go through, so it's not able to actually regulate a high volume. It is not however hooked inline with the driver side regulator, it's it's own circuit. I think you knew that already, but the way you typed it was ambiguous.
Additionally return lines are very sensitive to pressure changes (this is why it's actually often recommended to have a larger return line than supply line for the best pressure control).
Just FYI I have nearly the same as what you're trying to do, except I have the blockoffs and flow through regulators installed in the tank and my OEM supply is teed into the output of my secondary pump.
Also the passenger side regulator acts more like a check valve. When system pressure drops below a certain level, no more flow goes to the jet pump. This keeps the system from dropping pressure when you shut off the vehicle since the jet pump would be a leak and the system wouldn't hold pressure. Think of the passenger side regulator as being a pressure regulator with the return feed/discharge being to the jet pump.
Also, as someone else already pointed out, all of the bypass/return flow from the passenger side regulator has to flow through the jet pump orifice so it can only leak so much flow/pressure. The orifice size is fairly small so only a small volume/mass of flow can flow through the orifice, even at fairly high differential pressures.
Our passenger side regulator eliminator block allows the passenger side jet pump (that transfers the fuel to the driver side) to work at pressures below the normal passenger side regulator pressure. This is needed if you run a vacuum referenced fuel system or a system pressure that is below the passenger side regulator pressure (otherwise the passenger side jet pump won't operate). When you are using our passenger side regulator eliminator block it is assumed you are using an external regulator with a return line and check valve so that you can still hold pressure on key off.
I realize the regulator is slightly different, and yes if you use an external check valve after the stock pump you will hold line pressure between the check valve and fuel rail.
I like the less fittings the better, my fuel system I designed actually holds pressure, has no external check valve and still holds pressure key off
ohh and its all in tank. I'll post pics of how I did mine.Also the passenger side regulator acts more like a check valve. When system pressure drops below a certain level, no more flow goes to the jet pump. This keeps the system from dropping pressure when you shut off the vehicle since the jet pump would be a leak and the system wouldn't hold pressure. Think of the passenger side regulator as being a pressure regulator with the return feed/discharge being to the jet pump.
As for me saying "preferrred method" I mean it's the only recommended method for a return style boost referenced fuel system. Feel free to call any of the aforementioned companies or kinsler or any other reputable/knowledgeable person if you want further clarification.
When I said contradictory statements I was referring to you saying they don't use any kind of orifice or limiting device (which they do as you can order replacement parts) then the next sentence you said they do use a orifice?
If I make it huge will you actually read it and figure it out? look, you're wrong and this is getting so stupid. Go take apart your regulator. This is the last time I explain the same thing over again. The inlet and outlet of the regulator are not limited from each other, it is a straight through shot. The orifice is on a tee NOT inline. The pressure going into the regulator is exactly the same as the pressure going out. I understand this is hard for you to wrap your head around but it's a fact, you can test it if you would like. The regulator only bleeds excessive pressure.
Believe it or not the only difference between the pressure at the pump outlet in the rear of the car, and the pressure at the fuel injector is whatever the pressure drop of the line is.
The important thing to this point is it's completely unnecessary to place it after the fuel rails if your hoses are sized properly. The reason for doing this is to eliminate any variance in control pressure from pressure drop.
Like I have gone over AGAIN at the beginning of this post, there is no limitation of flow "upstream" or "downstream" of the regulator, it's a straight through shot. period.
He wont link the actual install instructions because it says exactly what I have. By "optimum performance" they are referring to what I already talked about with the possibility of pressure drop through restriction (wont happen if your lines are sized properly). http://aeromotiveinc.com/wp-content/...3101-09-14.pdf
