C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Solid Roller setup on a Daily Driven Z06?
Old Jun 7, 2013 | 12:30 PM
walhan_qtr's Avatar
walhan_qtr
Default Solid Roller setup on a Daily Driven Z06?
anyone has a similar setup?
I am thinking about going solid roller but worried about the maintenance involved. I would like to be able to rev this thing higher and make over 650whp with 11.5-12.0 compression. would you recommend it?
I will have about 250-300miles a week that involves city and highway driving and some racing too. how often will I need to check and adjust? also any recommendations on lifters or certain parts that works better than other? I am welling to spend the money and make sure I am getting quality parts. I have LSX DR heads and would like to be able to actually benefit from them and their flow and make some good N/A and nitrous power ( I have a nitrous outlet spray bar kit with 250shot)
any help would be appreciated!
Old Jun 7, 2013 | 12:51 PM
wildgoat's Avatar
wildgoat
I looked into this a while back when I considered buying a motor that already had a solid roller setup. I use my car about the same as you and was told I would be fine adjusting once per year which is not bad considering how aggressive you can setup the top end. To take advantage of something like that though I would go with higher compression (above 12:1). I've seen 13:1 LS7 on 93 octane run just fine (no additives or meth).
That's all I've got, good luck!
Old Jun 7, 2013 | 04:52 PM
walhan_qtr's Avatar
walhan_qtr
I don't want anything higher than 12.0 because I would like to be able to run 91oct without having to take all the timing out. I think the highest I have seen (and was efficient) was around 12.4-12.5 with 93oct and no meth but I might be wrong.
any idea on brands that I should stay away from or so?
Thanks either way!
Old Jun 7, 2013 | 05:34 PM
Gabbiani's Avatar
Gabbiani
Can't look at just static compression. If you are considering a solid roller I'm guessing you are considering something gigantic which puts a big hit on your dynamic compression.
The setup is much less forgiving and can make more power. As far as tech has come I am happy in the land of hydraulic stuff. Solid has to be perfect on preload. PTV becomes a bigger issue.
I would say find someone who has a setup you can check out. They sound nasty.
Last setup I worked on was a 427 lsx that made 680 through a turbo 400 and 9 inch. It was no slouch. That was at nearly 8k and the owner wouldn't let us spin it higher. I absolutely would not want to daily drive it though.
Old Jun 8, 2013 | 02:05 AM
walhan_qtr's Avatar
walhan_qtr
Thanks... I might end up with a hydraulic cam I don't know yet. I am trying to figure this out I do drive the car almost daily especially in the summer. we will see how that goes...
Old Jun 10, 2013 | 09:45 AM
carlos@redline-motorsports's Avatar
0carlos@redline-motorsports
Former Vendor
What are you trying to build? SPECIFIC combo I mean. Where is your target redline?
Old Jun 12, 2013 | 12:50 PM
walhan_qtr's Avatar
walhan_qtr
Well I bought those DR heads, LSX carb style intake with nitrous outlet spray bar kit, and new ARH 2" headers to fit those DR heads, and now looking for a cam. My target is to hit 650+whp and still be kinda ok to drive it around every weekend.
To Solid Roller setup on a Daily Driven Z06?
