C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What mods are needed when adding nitrous
Old Jun 9, 2013 | 10:30 PM
BSharkey's Avatar
BSharkey
Default What mods are needed when adding nitrous
I currently want to add 2 10lbs of 150 shot wet nitrous from nitrous Dave. He's got me set up on a safe great kit that includes spark plugs. I wanted to know what upgrades should I address to optimize safety and performance on my currently stock LS3 manual C6. Thanks guys...
Old Jun 9, 2013 | 10:50 PM
BSharkey's Avatar
BSharkey
Default Also
I want to build a custom fiberglass inclosure for my w7 which would place the woofer between the two bottles. Will the vibrations from the woofer have any negative impacts towards the nitrous. Which set up is better the puck from nitrous outlet or the spray bar from nitrous express?
Old Jun 9, 2013 | 10:55 PM
BSharkey's Avatar
BSharkey
Nitrous express hidden spray bar:http: //youtu.be/8NWG0aKfMtQ
Nitrous outlet puck: http://nitrousoutlet.com/index.php/nitrous-puck
Old Jun 9, 2013 | 10:59 PM
corvette8189's Avatar
corvette8189
Give NX a call and tell them billy sent u and they will hook you up. I also have a used setup in the for sale section that would be perfect for 150 shot.
Old Jun 9, 2013 | 11:02 PM
BSharkey's Avatar
BSharkey
I have already purchased everything except for the puck or spray bar still debating. Thanks though. I don't know which is better for my set up.
Old Jun 10, 2013 | 09:14 AM
dsp300c's Avatar
dsp300c
i have a C6 standalone fuel cell for sale along with other nitrous parts. you can run race gas in it for safety. i'm local to you as well.
Old Jun 10, 2013 | 09:30 AM
carlos@redline-motorsports's Avatar
0carlos@redline-motorsports
Former Vendor
The TB plate is what you need for a 150 shot. The NOS Mini Controller is a nice, inexpensive way to address the WOT switch, Window Switch, Delays and ramps all in one unit.
Old Jun 10, 2013 | 10:53 AM
BSharkey's Avatar
BSharkey
I guess the question I'm asking is; do I need to address the headers, x pipe, exhaust, intake, cam, heads or any other mods to run nitrous safely.
Old Jun 11, 2013 | 04:25 PM
Seadawg's Avatar
Seadawg
I'm looking to go this same route with my stock LS3 as you are, and from everything I've read, if you go with a 150 shot or less, everything with the engine/drivetrain should be OK.
Getting a proper nitrous tune is what everyone unanimously says is the most important item.
My plan is to start with a 75 shot jet, get used to it, fine tune the kinks, then work up to the 150 shot over time as I get comfortable with the bottle boost.
To What mods are needed when adding nitrous
