C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
removing supercharger need help.
Old Jun 12, 2013 | 11:31 PM
Assassinx1's Avatar
Assassinx1
Default removing supercharger need help.
Hi guys I have a 2006 LS2 im removing the m122 from it. I need to know what size maf to buy and what size injectors to buy to return it to stock. Also If i was to buy a tuner with preset tunes. It should load a stock like tune back into the ecm so I can remove the custom supercharger tune?
Old Jun 13, 2013 | 08:12 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
You can buy the factory MAF and injectors for your car direct from GM. Do you have a handheld programmer for the car by chance? If you do you can reload your stock calibration back into the car. If not you can always have a GM dealer flash the PCM back to stock as well.
Old Jun 13, 2013 | 11:06 AM
Assassinx1's Avatar
Assassinx1
Thank you. My fuel pressure is at 70 psi is this too high or will it be fine when I install the stock injectors? The car was tuned at your shop Chris. I should be able to buy a preditor tuner and use a preset tune to erase the ECS tune and put a "street tune" which should be close to a stock tune?
Old Jun 13, 2013 | 11:58 AM
bmfvette's Avatar
bmfvette
Cheapest place to buy a stock LS2 TB is Amazon.com
Old Jun 13, 2013 | 12:30 PM
Cruise-In V Veteran
If you want you can just send us the PCM and I can load a stock fine into it for you. You just pay for shipping. Are you returning the car to complete stock? I am sure I can get you a set of stock injectors as well.
Old Jun 13, 2013 | 12:37 PM
Assassinx1's Avatar
Assassinx1
That would be awsome how much would you want for the injectors?
To removing supercharger need help.
