C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS2 bottom end for boost?
Old Jul 3, 2013 | 11:38 PM
BigBadWhitey's Avatar
BigBadWhitey
Hmm ok, think im going to go for it then. And really no worries about the open hole? Just seems a little sketchy to me is all.
Old Jul 4, 2013 | 10:10 AM
old motorhead's Avatar
old motorhead
The hole will be covered by the washer on the crank pulley bolt.
Old Jul 10, 2013 | 10:18 PM
BigBadWhitey
Ok so i bought the crank.
Does that change things as far as compression ratio goes? Do you still feel ok running 10:1 on pump gas, 10 psi, with 402ci?
I live at about 1100ft above sea level, and the local track is at 5100ft (West coast canada, mountains)
With a 10:1 compression ratio and all things factord, I calculate a dynamic compression of about 12.5:1 under boost and a cylinder pressure of 145 psi using a ABDC of 70 degrees. Both of which drop at altitude. Do those feel like safe numbers?
Anyone have any more insight with cylinder pressure? What do you feel is safe?
