C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Stand alone fuel system ..
Old Aug 4, 2013 | 12:54 PM
Dsmauney's Avatar
Dsmauney
Default Stand alone fuel system ..
Hey guys I have an 05 c6 with ported heads and cam car is currently making around 470. I'm putting the NX 102 mm plate on the car when I return from vacation, my current idea is running a Holley blue upfront with a small fuel cell ! Will this setup be ok on a fuel injected car I know this is used on carburated cars all the time but will there be problems with this being a LOW pressure system ?? Thank you all in advanced for your help
Old Aug 4, 2013 | 04:17 PM
jon6.0's Avatar
jon6.0
You can run a low pressure standalone just fine as long as the jets you use are based on that fuel pressure. I wouldn't run a low pressure system if you were boosted, but NA you will be fine. Nitrous Outlet makes a dedicated nitrous fuel cell with a pump installed in the cell. I believe you have the option of low or high pressure. Your idea would be much cheaper though if you relocate the battery and get a universal fuel cell to fit where the battery went.
Old Aug 4, 2013 | 04:37 PM
Dsmauney's Avatar
Dsmauney
Awesome thanks man ! yeah I have seen a few of the relocation kits I have a friend that is an amazing welder he build cages he is gonna mock up a fuel cell for me .. Thank you again for your help
Old Aug 4, 2013 | 04:55 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
this would be perfect for you
http://forums.corvetteforum.com/c6-p...r-nitrous.html
To Stand alone fuel system ..
