Anybody know what (APS)turbos I have???
I have been tring to find out what turbos I have the serial number on them reads 780-062-400, I have looked at all the turbo part numbers on aps' site and found none to match? I'm trying to get these identified so I can get new seals in them!!
thanks
thanks
That is the same APS number I have on mine. That part was made by APS and has a design flaw in that the impeller blade rubs on the housing. The rest of the turbo is by Garrett and I believe it is a 3074 but it's been awhile since I looked it up. The Garrett part number is mentioned in a couple of old thread. I should also mention that I had the oil seals in mine upgraded to an overlapping oil seal. I didn't like the gap in the split ring type seal.
BJK
BJK
BJK
BJK
Frankie
First of all, I found this thread: http://forums.corvetteforum.com/1571229732-post10.html
And the Garrett part number is 3076R. I can't comment on the upgraded seal as the car is still up on jack stands. I do still have the stock system, but I will probably upgrade the intake side by doing the AtomicC6 mod. I also upgraded the scavage pump to a Turbo Werks pump and installed a one way valve on output side to reduce oil pooling in the turbos.
I also found out that just because the turbos smoke sometimes doesn't necessarily me the oil seals a bad.
BJK
BJK
Because of circumstances beyond my control, my car would sometime set for extended periods of time and oil would pool up in the turbos and end up dripping on the garage floor, so when I decided to upgrade my entire driveline, I also pulled the turbos and took them in for the same reasons you have. That's when I found about the impeller rubbing and saw that the oil seals are really a metal split ring with a gap big enough to allow oil to slowly seep. It only cost me a little over $300 to have them inspected, grind down the intake housing where it was rubbing, upgrade the seals, rebalance and put back together. I the future I will have the rear of the car elevated 3-4 inches when setting for extended periods so that the oil doesn't pool in the turbos.
BJK
BJK
yea I have seen the first thread u should me, that's what I thought I had, another shop looked at the turbos and said I have an internal gated journal bearing turbo and not a external gated BB turbo, that's why I figured Id ask around on here from y'all that have experience with these kits! that second link looks like a good idea, probly going to end doing that as well, thanks 07Monte!
Frankie
Frankie
Well this maybe true as it has been a while since I tried to call them, but they did answer the last time I tried calling and was able to talk to someone etc... and that would have been late 2011 early 2012 so this timeline is in your favor lol. Glad you found what you were looking for.
Well now it just depends on if I actually want to rebuild these or get the DKT upgrades, but know I kind of know what I have, Devon @ DKT offers the PTE 5830, or the LG upgrades but I will start a thread with that question soon also! wish I could run the 6266 but it will not fit on my kit!
