C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Drop on boost
Old Aug 20, 2013 | 11:52 AM
C6BOOSTED's Avatar
C6BOOSTED
Default Drop on boost
I have an 06 A6 with an A&A v3 with 3.4 pulley and I notice at wot it quickly hits #10 and they drops to 5-6 pounds when tranny shifts. takes a while to build boost back sometimes doesnt even hit #10 again. Is this normal ? this a slipping belt? Boost leak? Bad BOV? Btw the belt is pretty new 1k or less but its a Dayco brand and I checked the adjustable belt tensioner and its on tight. Any help would be great
Old Aug 20, 2013 | 01:07 PM
jon6.0's Avatar
jon6.0
Centris build boost with rpm, so your boost will drop with RPM. You sure something is going on?
Old Aug 20, 2013 | 02:50 PM
Unreal's Avatar
Unreal
Sounds normal. You hit peak boost before redline or right before it shifts, then it drops back down.
Old Aug 20, 2013 | 03:37 PM
Drewstein's Avatar
Drewstein
Sounds normal to me as well. Maybe data log your MAP reading just in case. It should have a similar pattern in each gear.
Old Aug 20, 2013 | 06:50 PM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
You will build 9-10 psi at peak, if you notice though at like 6000 RPM your going to be 1-2 PSI less than peak. Like stated a CENTRI blower is RPM based. you probably dont have a issue.
what RPM does your motor drop down to when it shifts?
Old Aug 20, 2013 | 08:57 PM
C6BOOSTED's Avatar
C6BOOSTED
Ill check what rpm it drops to . I wasnt sure if it was normal. Plus im trying to fix any lil bugs out before I take it to get it tune next month
Old Aug 20, 2013 | 09:43 PM
jon6.0's Avatar
jon6.0
Wait, wut? Are you getting on it untuned?
Old Aug 20, 2013 | 09:57 PM
C6BOOSTED's Avatar
C6BOOSTED
Lol it was tune for the supercharger a while ago. Then retune for meth. Then I did a cam and haven't retune. But I found out there was a leak in my alky system, got that fix now and notice about the boost drop while keeping an eye on my alky. I just want everything working probably for the tuner when ready
To Drop on boost
