Everyone is talking about this like it's something extremely expensive. Personally I would run meth at a decent power level. It's not necessary but it's a good safeguard just in case. It lowers IAT's and you can make a little more power from it. Better to have it and not need it than not have it when you do need it. It's only a couple hundred bucks for a good kit. If you're already supercharged just spend the money and have peace of mind. Sure you can run without it in a stupid hot environment but you can always run a little cooler and safer with it.
As for it eating up the coating on twin screw blowers it does according to multiple threads and sources I've seen but from what I've gathered it has no effect on the supercharger.
I just talked with Rodney at AIS for about an hour. We went over my cars combo and he recommended a dual nozzle kit with stainless lines since I want to run either 80/20 meth to water or just straight meth. He recommended two 12 GPH nozzles for me. I run 12psi up top. He recommended against a progressive controller for me. Just set it to turn on at 7 or 8 psi. I was going to do the rear cubby tank but decided to use my windshield washer fluid reservoir instead.
Thanks. AIS has a 14 GPH or an 18 GPH. I guess I'll try the 14 GPH first and see how it does. The stupid AEM kit only comes with a 550 cc/min(about 9 GPH) as the biggest nozzle.
Only use the AIS tank. Use an Alky Control meth system.
You want it to ramp up the meth as boost/airflow go up. Just starting to dump twin nozzles worth of meth at 700rwhp will make it go ultra fat then lean out a bit to super fat. You want it to ramp up so you can have a nice steady AFR.
jon that is similar to my setup, i run a 10 and a 15 and have it set to spray at 4psi, but i think ill look into a progressive possibly.
To me it's cheap and works great regardless of your type of FI. Is there more power found elsewhere? Sure.... but why chance it.
Indeed! Not too mention that when ambient temps climb, the car will pull timing. Whatever hp #'s your dyno sheet says, what you achieve at the wheels in those conditions will be far less. A good water to air cooler will also be a big plus.
Y'all got me paranoid now. I cancelled my AIS order. Talked to Julio at Alky Control and he said since I only want to control the IAT I should only use a 10-12 GPH single nozzle. Not dual 12's like AIS wanted me to run. The regular generic C6 kit comes with a 15 GPH nozzle and if you want a custom sized nozzle it's best to order straight from Julio. I will say that once you add up all the features you get in the Alky Control kit, it is actually not a bad price. The AIS kit I cancelled was a dual nozzle with stainless hoses for $500 shipped. No progressive though. That would have been another $200. So like system for like, the Alky Control would be a hair cheaper.
I agree with Julio. If all you want is IAT cooling then a single small nozzle is more than enough. It will keep intakes temps down without running so much meth/water that is whacks out the tune.
I need to call him back and ask about what I need for a 91 octane plus meth tune. I would like Nic to do a 91 tune so I can do a mega road trip up to PA next year.
