C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fighting valve float -- Trunion Kit?
Old Oct 4, 2013 | 10:46 AM
99NassauVette's Avatar
99NassauVette
Default Fighting valve float -- Trunion Kit?
Hey guys,
My car is floating up top and I've decided on the following to help resolve the issue:
BTR .660 Spring Kit w/ Steel Retainers
Comp Cam Push Rods
Should I go ahead and upgrade the trunion on the rockers? Wasn't sure if I might as well attack that while I'm in there or not.
Car is an LS3 crate motor with a GM HotCam installed currently.
Thanks!
Old Oct 4, 2013 | 11:01 AM
Unreal's Avatar
Unreal
Do Ti retainers if you want help with float. Trunions are nice but I wouldn't expect them to help with float.
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
If you're fighting valve float I'd highly recommend the Ti retainers to keep the valvetrain weight as low as possible. Not like the trunion upgrade will do anything for the float but it's cheap insurance against losing needle bearings in your motor. The swap is easy and quite fun actually.
Originally Posted by 99NassauVette
Hey guys,
Comp Cam Push Rods
Thanks!
Old Oct 4, 2013 | 11:10 AM
99NassauVette
Phew! Sure am glad that I posted here before I hit the purchase button! lol...
Would I achieve any benefit by just upgrading the rockers at the same time? I only want to do it once if I'm going to do it. (I only drive the car about 5-7k a year)
Thanks!
Old Oct 4, 2013 | 11:14 AM
Unreal's Avatar
Unreal
No benefit for float from rockers. Only way would be a lighter rocker but no one makes a lighter than OEM rocker, all of them are heavier.
Old Oct 4, 2013 | 11:15 AM
Dragracer_Art's Avatar
Dragracer_Art
IIRC, the factory rockers are already pretty lightweight.
I've read many stories about aftermarket rockers being heavier than the stock rockers and causing valve float issues.
Good valvesprings and lightweight retainers are usually a good option... and alot of guys actually seem to prefer the stock rockers.
Old Oct 4, 2013 | 11:16 AM
Dragracer_Art
Are you sure you are floating valves and not hitting the rev limiter ?
Old Oct 4, 2013 | 11:23 AM
99NassauVette
You gotta give me a little more credit than that! Sheesh. Yes it's floating the valves between 6k-6500. If I had the dyno sheet here I could show ya... I'll post it later this evening.
Old Oct 4, 2013 | 11:33 AM
Dragracer_Art
Well I HAD to ask...
Your trunnion question wasn't exactly a question I'd expect from a well-seasoned throttle jockey.
Old Oct 4, 2013 | 01:05 PM
99NassauVette
lol fair enough.. I've just never upgraded trunions before... generally we just swap for different rockers, Learning now that it doesn't help much on the LS3. So trunion upgrade here I come!
Old Oct 6, 2013 | 07:48 AM
Octane sipper's Avatar
Octane sipper
i was using yell terra but had float, whent back to stock and everything is good
Old Oct 7, 2013 | 02:04 AM
blf0005's Avatar
blf0005
I'd say definitely do the trunions! why wouldn't you? Since you'll have it apart it's the perfect time for a cheap and easy upgrade! You don't want the stock careless needle bearings to explode all throughout your motor!
Old Oct 7, 2013 | 05:55 AM
narfdanarf's Avatar
narfdanarf
^i've seen a lot more upgraded trunion failures over stock. That's why I personally wouldn't do it.
Old Oct 7, 2013 | 07:53 AM
jon6.0's Avatar
jon6.0
I too have read about some failures with the upgraded trunnions. I don't know if it's an install issue or a bad component. You can do some searching and see pics where they look galled. I personally just left my rockers stock and I usually shift around 6700-6800rpm with a 7000rpm rev limit. I'm using the BTR dual springs with tool steel retainers also.
Old Oct 10, 2013 | 11:47 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Failures are most likely from someone using a vise as a press.
Like most things, it's the small details that can cause big trauma.
Old Oct 11, 2013 | 12:00 AM
SteveDoten's Avatar
SteveDoten
http://forums.corvetteforum.com/c6-f...-a-rocker.html
How did the heads/chambers look during the lifter replacement
Old Oct 11, 2013 | 07:49 AM
99NassauVette
Originally Posted by SteveDotenMotorsports
http://forums.corvetteforum.com/c6-f...-a-rocker.html How did the heads/chambers look during the lifter replacement
They look perfect considering we dropped a brand new LS3 into her. the valve float is on a brand new motor.
To Fighting valve float -- Trunion Kit?
