C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
FI fuel options
Old Oct 13, 2013 | 11:38 AM
ricefed's Avatar
ricefed
MI Events Coordinator
Default FI fuel options
I'm looking for the best options to fix my issue. I have a 07 vette with a A&A kit. I have the s-trim with a 3.8 pulley. I've been having a fuel pressure issue once the car has been driven around a while and gotten hot. I believe my fuel pump is not producing after getting hot. My normal pressure is right around 62psi. After driving an hour or so it stays at 62 until I get on it and drops into the low 30's and I can feel a major difference. I'm wonder would I be better off putting in a bigger fuel pump or add a meth kit? Or maybe someone can add something else I can look into. Thanks
Old Oct 13, 2013 | 11:40 AM
ricefed's Avatar
ricefed
Also I'm planning on switching to a 3.4 pulley.
Old Oct 13, 2013 | 02:07 PM
LegendSS28's Avatar
LegendSS28
Do you have a boost a pump installed? With a boost a bump and stock fuel system you should be fine at your levels, as well with the 3.4 pulley most likely. It will be a pushing the stock system + BAP but should still be fine.
Meth will help with fuel/octane/temps but is not the solution to a fuel issue. I would add meth when you pulley down but for sure figure out the fuel issue
Old Oct 15, 2013 | 05:20 AM
ricefed's Avatar
ricefed
Yeah I got the bap. Thinking maybe if I add an inline pump it would help.
Old Oct 15, 2013 | 06:49 AM
Dragracer_Art's Avatar
Dragracer_Art
Do you have a Casper's fuel pump hotwire harness ?
The factory wiring is way too small and has horrible voltage loss.
I run the hotwire harness and a Kenne Bell Boost-a-pump without issue.
A 3.4" pulley and meth kit will definitely wake the car up too.
Old Oct 15, 2013 | 09:27 AM
ricefed's Avatar
ricefed
No I have the stock harness. Is the caspers a plug and go or do I have to splice it in? I'm only having the problem when the car is hot from driving 45 minutes or longer. So I'm not sure if it's just the pump getting hot or not.
Old Oct 15, 2013 | 12:16 PM
Dragracer_Art
Yes it is a plug-n-play kit.
It has a heavy wire that runs from the alternator to the fuel pump harness plug in the LR wheel well.
You will need to take the LR wheel off and remove the splash shield to install the kit.
The heat issue is probably related to the factory wire heating up, increasing resistance and lowering voltage seen at the pump.
Test it with a Fluke meter before and after the Casper hotwire harness and you will see a difference.
I did mine 2 years ago... so I don't remember exactly what the voltage loss was... but I seem to recall the OEM harness was only supplying 11-something volts to the pump when the engine was running.
The Casper harness put 14-something volts to the pump. The KB BAP jumps it to 17-something when needed.
In my opinion... the fuel pump hotwire harness should be a mandatory upgrade and one of the first things in a list of mods done to these cars.
Old Oct 15, 2013 | 12:26 PM
ricefed's Avatar
ricefed
Awesome thanks for the info. I just ordered it so I'm hoping that solves it. That's way cheaper than another pump lol.
To FI fuel options
