*** Special on Magnuson Heartbeat this Fall **
#1881
#1882
Okay, great. I'm glad - as comparing the two, the Micro L2 is much more grippier..they both look the exact when I took photos, it's deceiving in that you have to actually touch them to feel the difference.
Sammy, you might wanna try an L2 brother. That may help slippage...?
Thanks!
Thanks!
Mitch/Sammy,
I just ordered the 3.2" griptec from Capa Performance here in Australia. It has the L2 micro stamped on it as well from the photo they sent me.
If you go to the griptec site, they also have a L3 for certain jackshaft maggy pulleys, but not all of them. I was going to e-mail them about the differences,
but just decided the L2 version would be ok. I googled the L2 version and i am convinced it has another level of abrasiveness over the normal griptec. As
for the L3, i'm not sure?
CI GS (07-14-2018)
#1883
If ya'll ever go to San Francisco and talk about your different trannies and how tight they are, how they shift, slip, etc., you'll be right at home... Just be ready for some advances from likely unwanted people...
#1884
https://www.youtube.com/watch?v=kjbLruhTaxU
Chiselchst (07-14-2018)
CI GS (07-14-2018)
#1886
Mitch/Sammy,
#1887
Ha, blame me if you must, but I wasn’t the one that said that I prefer getting my kicks pulling on a stick!
#1888
#1889
I'm about 30 miles from San Francisco, but it might as well be 30 light years...I can't even watch the news anymore...what the new "normal" is, LOL
I ordered me an L3 Micro! I have a 3.4 in L2, now I'll have a 3.3" / 82mm in an L3...
Good God. I find this world a scary place these days: How in world are you supposed to figure out who is what? You can’t go by appearances, and if you ask them, you’ll get sued, and you can’t do the Crocodile Dundee/Trump crotch check thing anymore, or you’ll get locked up, so what’s a man supposed to do to find a female without getting “shafted”??
#1890
So I received an L3 Micro Finish 3.30" Griptec today.
Comparing the L3 to the L2, I like the L2 much better (by feel). Just feels coarser by hand.
Check out the newer pulley design. I swear they look like different ID's, but they are both marked 3.30". I'll put my trusty Harbor Freight micrometer on them to measure...
Sammy, have you ran an L2 or L3 Micro finish Griptec? Compared to a stock Maggie pulley, they sure feel like they'll hook better...and feel better than the Griptec's made for SCOL, IMHO.
CI GS (07-19-2018)
#1891
Chiselchst (07-19-2018)
#1892
My new 3.4 griptech is a flat top not bulged our. Is that the new style? And I’m not seeing slip. But am only doing 7.5psi
#1894
That’s the first time I’m seeing this new ‘flat-nosed’ GripTech pulley. Must be a new style. The two I have are tapered.
#1895
Just wanted to report back on how the RPM belt and Dayco tensioner were working out. In short, much better than the stock tensioner and Continental Elite (“Gatorback”) belt. The first good news is that even though I hit the limiter a couple of times trying to put heat in the tires, the RPM belt didn’t jump off like it did with the previous Dayco tensioner (which was definitely misaligned). I can’t honestly say that it was a back to back comparison though, because I also recently changed from my 1 3/4” Pfadt headers to some Kooks 2”, which I know are flowing waay better, so I figure I lost some boost from that swap. How much, I have no idea. But, man, is this old car making some power now. I couldn’t get it to hook in 1st gear yesterday on a (half-***) prepped track with my brand new M/T ET Street Rs, which I’m sure were hooking better than my old M&Hs.
Anyways, I made three runs down the 1/8 yesterday, the first one was to try to get the AFR dialed in a bit after the header change (the attached pic is a snapshot from the datalog on that run). The highest boost was during that first run - right around 13psi, which it only hit for a split second. But it was most;y in the high 12 psi range. Boost is still moving around a bit however, but not as much, and it’s definitely higher now, even with the much better flowing headers. It also fell off during the day, as the got hotter. It was also fukin steaming hot at the track yesterday, btw. The heat index was at like 106*!
On the other two runs, I raced against a friend with a new mustang with a 200hp shot on it and he left early on me (arm-drop racing “red-light”) I left way too hard and the Vette got so bent out of control that I had to ease and straighten it up, so he clipped me, but I was reeling him in like crazy at the top. So we did a rerun and I pedaled it in first, and second, up to about 43mph, based on the datalog, and gave him like 3 bus-lengths. Once I got it hooked, it pulled like a sonofabitch, even though the catalogs show that the AFR still moving around from high-10s to low 11s, the belt starting slipping a bit, and the IATs were fairly high from hot lapping it. A couple of people sent me some videos of the last run I made and it looked pretty impressive. Unfortunately, we don’t have the timing system going at the old track going as yet, so I don’t have any time slip (yet). I’ll see if I can load a video on you-tube later and link them on here.
So, I’m happy with this thing. I don’t think there’s anyone out there making 13lbs of boost on a Heartbeat in a C6. Once I get the fueling dialed a little better, and the new surface on the track gets some more rubber, I’m gonna see what this old junk can do...
The following 2 users liked this post by CI GS:
Chiselchst (08-01-2018),
rajahhindi (07-31-2018)
#1896
Is it just me, or is this new CF format a big PITA? You can’t even edit this **** properly! Why, why, oh why do these ubiquitous forum computer geeks keep fukin around with **** when it’s already working?
#1897
I think I may order me one of those new flat-nosed GripTechs, BTW, with the roughest surface I can get.
#1898
Thats pretty impressive Sammy. 13 pounds with all that heat. Well done.
#1899
Received 1,194 Likes
St. Jude Donor '15
Car sounds like it's hauling ***, that's good to hear! Hopefully you can keep a belt on that thing and find some traction and have a good 'ol time
#1900
