FRA-371012 HOSE ASSY STR X STR ALUM NUT A $22.95 2 $45.90
RUS-644020 ADAPTER FITTING A $11.95 1 $11.95
RUS-650400 BILLET Y BLOCK A $17.95 1 $17.95
RUS-670343 FITTING $13.95 1 $13.95
SUM-220166B -6 O-RING TO -6 FLARE FIT BLK A $6.95 4 $27.8
I swapped a 12" line for an 18" fuel line so im not messing around between the blower and firewall
All parts ordered from summit to make the Y setup that connects to the E-Force fuel rails
Im ordering this stuff tomorrow and ill post how the install goes when it all comes in.
Chris
Chris
Interesting. Don't you even THINK of forgetting to do pictures and steps on this.
Chris
Hi Chris, i am curious, What is the purpose of this setup?
This also reminds me, i did have a o ring go bad on the 180 deg fitting that feeds the fuel rail on the drivers side. It appears that the o ring was not as compatible with gasoline as it needed to be. It Looks like it melted and lost its shape. Anyone else ever experience this on an e force setup?
If you follow the path of the fuel by the time you get to cylinder number 7 its already pulsed past seven other cylinders and could be starving just one cylinder not showing up on the wideband o2 sensor
You could definitely make yours look/fit better but i had the 2 pre-made lines already and it saved a ton of money. Plus I didn't want to mess with the fittings on the fuel rails if i didn't have to, I've had bad luck with an-threads in the past
Looks fine to me. I couldn't even find black fittings when I did it, but I have since covered it with heat shield so the fittings don't show anyways now.
Nice that's how i was planning mine but i had those lines and saved a bunch of $
keep an eye on the fuel line from the body mine came off the stud on the fire wall and was rubbing the line on the threads, eventually would have wore a hole. probably from the extra weight of the new lines
Good point. I have it tie wrapped to that stud from the eforce cover to keep it from moving around. I also changed the connection to the factory line for a Swagelok stainless fitting. That crappy plastic thing cam apart and almost burned my car to the ground. I got off easy that time.
