Fuel Pressure Sensor mounting
BUT! This time I'm going to use this fitting rather than yank out the fuel rail. I will take more pictures while doing the install and post them here but this sure looks like the easiest way to install a fuel pressure gauge. Fitting plugs on to OEM fuel line connection, OEM fuel line plugs onto fitting. Fuel pressure sensor screws into Nitrous Express 16185 3/8 - 10MM fuel rail adapter fitting. All I need now is for the bloody fitting to be the correct size and this could be easy!
First picture: Shows where the sensor will sit on the driver's side of the engine.
Second: More relational view of installation area.
Third: Sensor installed on fitting.
Fourth: Fitting end to connect to OEM fuel pipe with METAL clip.
Fifth Totally bad to use Russell 640730 Fitting DO NOT USE!!!
Do not pay any attention to the posts after this that mention I picked the absolutely incorrect part from Russell. Old people are fun to watch at times but we eventually get enough guidance and do stuff right!
Elmer
Last edited by eboggs_jkvl; Dec 15, 2013 at 05:23 PM. Reason: Correct part and picture update
old vs new..
BTW, I've e-mail the Swagelok distributor here in Jax for a price and availability.
I had made up my mind!
I like this better. I don't have to cut the fuel line and buy a bunch of fittings and couplers!!
Thanks for the post.
I've ordered this from Summit.Elmer
Are you just installing the gauge, or are you also doing the fuel lines to run to both rails? I would do that while you are at it.
I agree with your first post. Trying to put anything on the back of the passenger side rail is a pain. Very tight to work there.
Elmer
