I've had a oil leak problem since day one. Well today I got a call after it's third two week stay at the shop, and number 3 and 5 lost compression. Needless to say this sucks, after looking at everything, they found the blower was making way more boost on the street then on the dyno. It peaked at 11lbs on the dyno, but after checking everything it was hitting 10lbs at only 3500rpms and peaked at 15 to 16lbs on the street. All it has is a A&A kit, LG headers, ported intake manifold and ported TB. I'm trying to decide to either to throw two new piston and rods in or go fully forged. The block and heads are fine, so I'm leaning towards just fixing this motor. Just looking to what you guys think is the best route. Thanks
Man that just doesn't sound right. I know that ECS uses a restrictor plate that if removed or comes out somehow boost will increase quite a bit. A and A does not use a restrictor plate as far as I know. I cannot understand how boost could increase so dramatically like that.
If it was me I would forge the internals rather than go back in with stock. The motor is already down a few more dollars for forged internals seems like good insurance if you plan on keeping the car boosted.
The data logging I had in the car showed 15lbs. I don't know how accurate that was, but they said in was way more than what it was on the dyno. What is the cost to just put a set of forged pistons and rods in. I don't plan on going any farther than 700whp.
Since day one of what? Owning the car? Blower install? Need clarification please.
Initially, this to me sounds like a case of the dyno operators not having the load cell on the dyno calibrated properly. A change in load calibration on the rollers can wreak havoc on accuracy when trying to accurately dyno/tune a car. When you add the load imposed on the street (rolling resistance, aero load, gearing, hills, etc.) the entire behavior of the engine is different...something that a dyno can mimic when used by an operator familiar with this principle. You have a legit case to bring to the shop for them to supply a new motor. Their inexperience (or unfamiliarity) on their own equipment caused this failure. Plain and simple. When you say this to them, they'll ask...who told you that? Then they'll say I'm full of it. That's their denial setting in because they've been exposed. I have nothing to hide, nor anything to benefit from exposing their ineptitude. I've been dynoing cars for 12 years on numerous makes/models of dynos. I've seen more than most...and I just hate seeing incompetence from performance shops. Hell, I wouldn't be surprised if they try to blame it on your driving...
SI trim on that motor should be maybe 10-11 PSI MAX its just not enough blower to fill all that. If your cats were clogged up it would make sense though. 10 PSI at 3500 with that setup is a TON of PSI!!!
the Centri blower wont make more PSI on the street than on the DYNO. it is NOT load based so that also makes no sense.
If it were me or this was a customer of mine i would make sure he did a piston rod swap at a MIN. this was your weak link( pistons) are atleast gone and you can push her as hard as you want with that setup. The LS7 doesn't like that much PSI anyways so bad gas, a rev limiter a few times, your going to get that motor at those PSI levels every time.
I suspect plugged cats as well. As already mentioned, that blower and that pulley should put you nowhere near 15-16psi. The only reason possible for it hitting that boost is a restriction somewhere.
I'm spinning a T-trim with a 3.125" pulley and only get 12-13psi. I would just do forged rods and pistons. This will mean you have to have the rotating assembly balanced again though.
Exactly, and Jon is a ls3 not 7 which would be even lower boost because of the cubes/heads.
Wouldn't this be the opposite? A ls7 and ls3 with identical setups the ls7 would be pushing less boost because of all the extra space for air?
I.e. the ls3 would be at 15-16 psi and the 7 would be at 12-13? I'm not saying with a t-trim and 3.125" pulley these numbers are accurate but just using them for comparison.
Yes, that is what he meant. No way a healthy LS7 is making 15 psi with a 3.4" pulley on an Si-trim. My cammed LS3 made 11 psi or so with a T-trim and 3.4" pulley.
Clogged cats could be it, but I wouldn't expect a hike that high. I had a similar issue on my SI LS3. If I can find the old dyno graphs, I can show you the difference with clogged vs unclogged. Boost spiked to the same levels, but just fell right off after earlier in the rpm band.
