Hello all
Just finishing up my rebuild with a procharger install. Lookin for any recommendations on a competent tuner.
Here is a short list of mods on the ls7.
Stock bore
Callie's rods
Diamond low compression pistons ( neg 27cc )
Ported stock heads with Manley valves
Converted to wet sump
127lb injectors
Texas speed lsxr cam
Long tube headers with magnaflo exhaust
Aero motive in tank pump
Msd boost controler
Procharger f1-c
Reason: Added info
Sorry about that. I live in eastern oklahoma.
Cam specs 248/256 .662"/.648" 114+3 (with 1.8 rockers)
Yes on the maf
I will have to get the injector data
I'm not familiar with any tuners out that way. Hopefully somebody else will chime in. You could also try posting this in the regional section.
Matt would definitely be able to help you out, but it's a longer process than just a day at the tuner like somebody local. You want to take things slow and send logs back and forth. I have the benefit of living in the middle of BFE, so I have spots I do my 3-4 pulls and it doesn't cost me dyno time. I also send logs of just normal driving.
Contact Mike at Vengeance Racing, he can remote tune anything and knows everything about the LS series motors and more importantly the computers. He had tuned all 3 of my cars, I would not trust anyone else
If he's doing remote tuning there are a few good ones out there. Matt Sorian is treating me right and we are sneaking up on the tune since I decided to swap from E85 to 91 octane. Remote tuning is definitely harder on a tuner since they only have the logs and can't feel the car.
Yes on the maf
how far are you from st louis MO ? if its not that bad of a trip look up DSTECK
