C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Time for a new motor
Old Jan 7, 2014 | 08:25 PM
03SuperchargedZ's Avatar
03SuperchargedZ
Default Time for a new motor
The car started smoking yesturday morning so bad I couldn't see out the back window. While sitting at a red light, it looked it was on fire it was smoking so bad. So I had the motor torn down today and two pistons are cracked completely.
Now it's time to decide to either rebuild the motor or throw a new motor in and maxing out the blower and going all out. I was thinking either a 408ci or 427. I found the GM performance LSX 376 and it seemed like a good price for the overall package. I want to reuse my current blower and as much of my parts as I can.
I'm looking for ideas for the new motor and what to go with. I don't want to spend much more than $10,000 on the motor and then I'll some cash left for fueling and drive line parts.
What kind of power can I get from a A&A T-trim? Looks like my ford lightning build is getting pushed back for awhile. I was planning on building the motor but not this soon.
If you can give me a couple of your ideas on where to go with the build. I want to get about 750-800whp if possible. I might upgrade blowers later so I want to build the motor to handle a lot. Thanks
Old Jan 7, 2014 | 09:31 PM
NSANEC6's Avatar
NSANEC6
I went with a 427LSX from Bryan at LME in Houston. The fully forged build was a little bit more than your 10 k budget but its a place to start your search.
Old Jan 7, 2014 | 09:41 PM
Unreal's Avatar
Unreal
T trim will do that power. $10k on shortblock? Or with heads? Are your heads useable?
Crank and rods still good? If so just grab a new ls7 block, do some nice pistons and reuse you crank/rods and 800rwhp will be no issue.
Old Jan 7, 2014 | 10:02 PM
03SuperchargedZ
Haven't checked the rods yet. The heads are perfect with no damage. The motor will have the rods and crank removed tomorrow. I figured a new LS7 block would work.
Old Jan 7, 2014 | 10:19 PM
03SuperchargedZ
Will a new LS3 block work? It's about half the price of the LS7 block.
Old Jan 7, 2014 | 11:24 PM
Chance42's Avatar
Chance42
Look into doing an ERL block, they take cores...
Old Jan 7, 2014 | 11:41 PM
Detoxx03's Avatar
Detoxx03
Forged LS3 block and have at it. Too many people go way overboard here.
Old Jan 8, 2014 | 12:01 AM
NSANEC6's Avatar
NSANEC6
Hey, I resemble that remark!!!!
Old Jan 8, 2014 | 12:58 AM
Blk Beauty's Avatar
Blk Beauty
Just curious, what type of longevity did you get out of your engine? What type of driving when it let go?
Old Jan 8, 2014 | 01:02 AM
03SuperchargedZ
About 1,500 miles. it let out during just cruising but, I run the car hard. The car ran out of fuel and started to slowly lean itself out.
Old Jan 8, 2014 | 01:12 AM
03SuperchargedZ
I think I've decided on what I'm doing. I'm going with a ERL short block. Here's a list of what I've picked out so far, and let me know what you think of it.
Turbo Race Superdeck 427 with 9.7:1 compression with a Super deck 1 block.
Ported stock LS3 heads
A&A twin pump fuel system
Dallas Performance 4" intake
Not sure on the Injectors yet
Boost a pump
Alky Methanol kit with a dual nozzle upgrade
Monster twin disk clutch
So far that's what I've come up with. I plan on pushing my current blower as far as it can go also. Hoping to get 800whp once it's all said and done.
Old Jan 8, 2014 | 02:08 AM
Detoxx03's Avatar
Detoxx03
Don't need a 427 to achieve 800rwhp, better off getting a good set of heads over the ported LS3's, compression is fine and could go as high has 10.2:1 and lastly not many have luck with those clutches. ERL blocks are real nice and I plan on getting one when I do my build with the new Trick Flow 255 heads.
Old Jan 8, 2014 | 03:18 AM
03SuperchargedZ
I'm wanting to go with a 427 for the extra Tq. Also I plan on going with a YSI blower later this year when I get the funds. I figured 800 is around the max my current blower can put out.
Old Jan 8, 2014 | 07:54 AM
Unreal's Avatar
Unreal
Put money into heads? Is your car a Z or not? By the name I assume it is a ls7 car. The reason you don't see people doing ls3 blocks is the ls7 heads won't work under a 4.125 bore, and the ls3 block can't do that bore. So you can do a piston/ls7 block combo that will be fine for 900-1000, or sell heads/intake/etc and go a ls3 combo but need new heads/intake. Either one will make 800-1000 and have no issues taking what a YSI can throw at it.
Local makes 1090rwhp though a piston/rod LS3 setup with PRC heads. Another makes 1020rwhp on a 416 ls3 combo with PRC heads on a novi 2200.
Other issue if you go ls3 block is you will need an aftermarket dry sump crank to keep the dry sump on the ls7, or ditch it and go wet sump. For all those reason I would just do the ls7 block with good pistons/rods because it will drop in, and the ls7 heads will make way more power than the ls3 heads. If not look at a ls3 with good heads and convert car to wet sump.
Or ERL whatever block and it doesn't matter. I would still put decent heads on it.
Old Jan 8, 2014 | 09:02 AM
03SuperchargedZ
I sold my old 08 ZO6 and bought a 13 grandsport. I can't decide what I want to do. I'm leaning now after looking at everything is a forged LS3 with a good set of heads.
Old Jan 8, 2014 | 09:18 AM
old motorhead's Avatar
old motorhead
Originally Posted by 08BlackZ
I sold my old 08 ZO6. I have a 13 grandsport. I can't decide what I want to do. I'm leaning now after looking at everything is a forged LS3 with a good set of heads.
Bingo! That will take you a long way and won't break the bank
Old Jan 8, 2014 | 10:29 AM
Unreal's Avatar
Unreal
Perfect. Nice pistons/rods ls3 and some solid heads (trickflow, PRC, etc) and you will have a nice 1000rwhp motor. Only question is to do a stroker crank for more low end/daily fun or not. I would skip it and keep compression a bit higher. Go for ~10-10.2:1 and let that T trim spin at max.
To Time for a new motor
Old Jan 8, 2014 | 11:25 AM
Detoxx03's Avatar
Detoxx03
Exactly what I was getting at. Leave the stroker crank alone and keep the compression where I stated earlier. It's simple and will do what you want it to do.
Old Jan 8, 2014 | 12:28 PM
jon6.0's Avatar
jon6.0
If you are using E85 you could even bump the compression a little more to say 10.5-10.7 and be fine. If 93, then I would do 10.2 like what Detoxx03 said. I also wouldn't bother with a stroker crank. Good rods and pistons and call it done. If you want a little more support you can dowel pin your mains or use a main girdle. I've got a main girdle for when I build my LS3. It requires that you install it, torque it down, then line hone the mains. If you are keeping it around 800rwhp I wouldn't worry about it. But you did mention YSi, so it would be a good idea.
Old Jan 8, 2014 | 01:51 PM
DSteck's Avatar
DSteck
Pistons, rods, head studs, and run that bitch. That's all you need, unless one or more sleeves are damaged.
