C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Tapping intake for IAT?
Old Jan 21, 2014 | 02:03 PM
Dtownbrown's Avatar
Dtownbrown
Default Tapping intake for IAT?
Who all is tapping the intake for their intake air temp. ? How is it being done? I plan on going with the ls3 maf card in my 05 and running meth. I called
A&A and was told they mount the nozzles after the card and tap into the intake for the IAT?
Old Jan 21, 2014 | 02:52 PM
DSteck's Avatar
DSteck
Right behind the throttle body. You might have to cut a rib away. Just drill a hole and tap it for M14x1.5 (if memory serves me right). The sensor to use is 12614717.
Old Jan 21, 2014 | 03:16 PM
Dtownbrown's Avatar
Dtownbrown
Awesome . Thanks for the support. This is my first complete build and I'm still learning. Thank god for corvetteforum and you guys who help us newbies.
Old Jan 21, 2014 | 07:38 PM
D&C vette's Avatar
D&C vette
if you need a sensor, I have a new one. Will let go check + shipping.
Old Jan 21, 2014 | 09:34 PM
jon6.0's Avatar
jon6.0
I didn't tap mine. I installed a grommet and push in IAT behind the throttlebody. I made sure it's a really tight fit. I had to really lean on the IAT sensor pushing it in. Reacts really quick behind the throttlebody too.
Old Jan 22, 2014 | 12:34 PM
Jeffro_510's Avatar
Jeffro_510
I made a new intake pipe, and had a bung welded to it. I was scared that a push in would blow out no matter how tight the fit.
Old Jan 22, 2014 | 12:46 PM
jon6.0's Avatar
jon6.0
Mine hasn't moved, but I'm only running 12psi. Should be 14psi after my pulley swap tomorrow.
Old Jan 22, 2014 | 02:25 PM
Dtownbrown's Avatar
Dtownbrown
Pretty sure the fitting that's tapped into the intake is threaded in.
Old Jan 22, 2014 | 10:32 PM
Jeffro_510's Avatar
Jeffro_510
Mine didnt pop out at 14.5 i was already deleting the Maf and making a new pipe anyways so i figured i would get a bung welded in, as many issues as i have been through figured id rather be safe than sorry, especially since i was bumping the boost up a couple pounds.
Old Jan 22, 2014 | 11:02 PM
Dtownbrown's Avatar
Dtownbrown
How much power you making at 14.5 lbs? what engineand FI you have also?
Old Jan 22, 2014 | 11:06 PM
jon6.0's Avatar
jon6.0
I'm at 754rwhp. 12psi with 18* of timing on E85. I swapped to 91 octane so I'm trying to get some power back with more boost and less timing. Meth too. A single 15gph nozzle on a Alky Control kit running pure meth.
Old Jan 23, 2014 | 10:41 AM
Jeffro_510's Avatar
Jeffro_510
I was at 745 to the wheel on 91 oct.
Stock cube ls2, untouched 243s and ls2 intake. Paxton 2200sl head unit
Old Jan 23, 2014 | 11:01 AM
Unreal's Avatar
Unreal
ECS did my upper pipe and set it up for a push in. No issues are 18-19psi.
Old Jan 25, 2014 | 10:35 AM
slow goat's Avatar
slow goat
I bought a z06 air filter and an ls3 MAF for my ls2. I tapped the IAT in the intake tract before the TB and accross from the card.
To Tapping intake for IAT?
