C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS Restrictor Plate removed
Old Mar 2, 2014 | 07:00 PM
ATLS2's Avatar
ATLS2
Default ECS Restrictor Plate removed
anybody have any idea what will happen if I remove the restrictor plate on my ls2? I should be okay if I have good enough fuel, right?
Old Mar 2, 2014 | 07:28 PM
jon6.0's Avatar
jon6.0
You will get between 12-16psi depending on cam and exhaust setup. The more free flowing your setup is, the less the boost number will be. Probably somewhere in the mid 700's for RWHP if you have a cam.
Old Mar 2, 2014 | 09:15 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
My air filter and thus restrictor plate fell off and I drove around for a while before noticing. The motor stayed in on piece.
You pick up 4psi or so without it. If you have adequate pumps and a boost referenced system it should be ok.
Old Mar 2, 2014 | 09:30 PM
ATLS2's Avatar
ATLS2
I mean bad stuff. What could happen to my stock block?
Old Mar 2, 2014 | 09:35 PM
SinisterC6's Avatar
SinisterC6
Speedy
Most likely scenario is the higher boost causes a lean condition which usually breaks a piston ring or the portion of the piston which the ring sits.
Old Mar 2, 2014 | 10:40 PM
ATLS2's Avatar
ATLS2
So, enough fuel will fix that?
Old Mar 3, 2014 | 12:59 AM
SinisterC6's Avatar
SinisterC6
Speedy
Its not only the amount of fuel. After 11psi you need more octane or a colder intake charge to prevent knock.
Race gas is the simplest solution but depending on availability it is inconvenient.
Use meth injection adds a little octane amd also cools the intake charge. People have gone a long way on pump and meth with forged motors.
7 to 800 tends to be the limit of the stock motor with many people living at 5to 700 without issue
Old Mar 3, 2014 | 07:28 AM
MARSC6's Avatar
MARSC6
You will need meth and to have it tuned for the higher boost. ECS kit with meth, headers, and fuel upgrade I'm seeing around 14 PSI and 735hp with the plate out. Still stock internals.
Old Mar 3, 2014 | 08:58 AM
ATLS2's Avatar
ATLS2
If I was to make any changes to my internals, would changing the pistons be the only thing I should consider? I've heard people say that getting new head studs and a LS9 gasket are also a cheap insurance.
Old Mar 3, 2014 | 09:10 AM
jon6.0's Avatar
jon6.0
I'm doing that to my car now since I snapped the stock timing chain. Forged rods and pistons with the stock crank. New cam, link bar lifters, and Katech C5R timing chain.
Old Mar 3, 2014 | 09:40 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
This is the "magic combo" we have been doing on hundreds of cars with great success.
To ECS Restrictor Plate removed
