C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Why'd my car start?
Old Mar 2, 2014 | 09:01 PM
Dtownbrown's Avatar
Dtownbrown
Default Why'd my car start?
I was told there would be no way my car would start after my build. 05 c6. Was completely stock then I tore it down , put a 408 stroker - big blower cam, f1r procharger, 1000cc injectors , triple 255 walbro pumps, ls7 maf, etc. And many people was positive it wouldn't start with the big injectors and bigger cam.
Well not only did it fire right up It idles and revs up as if it's stock.
Am I just lucky or was I being lead to believe nonsense ?
Old Mar 2, 2014 | 09:40 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Are you saying it started and idles well with no changes to the previous tune? That is odd for sure but I definitely wouldn't drive it without logging and adjusting, no matter how well it seems to run.
Old Mar 2, 2014 | 10:06 PM
Dtownbrown's Avatar
Dtownbrown
Yes it idles and everything just fine without any tune at all. And I haven't driven it and won't until I do get a tune. Just thought it was crazy how well it ran without a tune. I did talk to a tuner a few min ago and he said it probably would start and run sense I'm running my stock throttle body and intake .
Old Mar 2, 2014 | 10:21 PM
playtoy's Avatar
playtoy
I would be careful running a stock tune with 1000cc injectors. That's a lot mor fuel being dumped in the motor
Old Mar 2, 2014 | 11:55 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Agreed... I guarantee the Fuel trims are -50%..... DO NOT start it again... or you will need another new engine.
Old Mar 3, 2014 | 12:32 AM
lt1z's Avatar
lt1z
If it really had a stock 05 tune in it you probably washed down your rings running a 114lb injector as a 33lb injector. That is 72% richer.
Old Mar 3, 2014 | 12:46 AM
Dtownbrown's Avatar
Dtownbrown
Explain exactly what washing down my rings mean?
And it actually didn't even smell all that rich, even with open headers.
Old Mar 3, 2014 | 08:20 AM
jon6.0's Avatar
jon6.0
Do you not have a wideband in the car? Washing the rings down is dumping so much gas in there that it screws up the ring seal. Meaning you get to tear down your engine to hone it and put in new rings.
Old Mar 3, 2014 | 08:23 AM
playtoy's Avatar
playtoy
Basically the extra fuel that is not being burnt is "de-oiling" the cylinder walls so there is no lubrication between the rings and cylinder walls. Dry cylinder walls will cause scaring which will lead to ring failure which means you have to pull the motor back out and rebuild it again.
Old Mar 3, 2014 | 11:13 AM
Dtownbrown's Avatar
Dtownbrown
Oh okay well I didn't run it that long. Just let it idle a minute
Old Mar 3, 2014 | 11:19 PM
C6z06man's Avatar
C6z06man
unscaled 1000cc injectors will wash those cylinders of your new engine very fast. Dont start until they are scaled..
Old Mar 5, 2014 | 08:10 PM
demonio1023's Avatar
demonio1023
Do as they say! Same thing happened to a friend of mine with 80lb injectors! He started it and drove it to the tuner, needless to say, he didn't make it there.
Old Mar 5, 2014 | 08:13 PM
Dtownbrown's Avatar
Dtownbrown
Oh yeah I'm not driving it anywhere. But after completing the build I couldn't help myself but to start it and check everything.
To Why'd my car start?
